Author Topic: Where can I find some mp3 jukebox software...  (Read 6362 times)
JustMichael
  • Mmmmm!! Cheesecake!!
« on: June 24, 2002, 01:56:55 pm »
runs on a vertical monitor?  That also uses Winamp to play the tunes?
  • Last login:Yesterday at 07:46:44 pm
Re: Where can I find some mp3 jukebox software...
« Reply #1 on: June 24, 2002, 04:21:43 pm »
Your not going to find it unfortunately.  I looked before I started on the dj.  The only decent full-screen winamp front-end I could find was at the winamp.com plugins section and it was very lacking in the features.  As for vertical forget about it.  :)
Make it.  The source to the dj is mostly api calls which work in Vis C++ almost exactly the same. Just port it and combine it with the gameluancher source, or something that can support rotated text.
OR if you have a radeon card, thier newest drivers support rotating the display at the driver level.  It takes about 10% of the normal framerate but for a mp3 player I don't think that would be a problem.
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
Re:Where can I find some mp3 jukebox software...
« Reply #2 on: July 15, 2002, 04:18:11 pm »
the next version of fe-3darcade supports playing of mp3 playlists and the fe can allready be rotated...
It uses an internal player though...
Peter
