Author Topic: Sega Rally 3 Command Line  (Read 7344 times)
RetroRacer
  • Last login:April 19, 2018, 10:54:30 am
« on: February 02, 2018, 04:49:03 am »
Hi all
I am trying to launch SR3 running in Tecknoparrot using AttractMode frontend.  I cannot find anywhere what the parameters are.  There is a lot of stuff out there for older version of TecknoParrot that use dumbjvscmd etc. etc. but that is no longer relevant to the latest versions it seems.
I found that you start with parrotloader.exe followed by the path to the game exe, then the profile of the same in xml format but after that it requires some parameters which appear to go in between <>.
So it may look something like this:
c:\tecknoparrot\parrotloader.exe c:\segarally3\rally\rally.exe --profile=sr3.xml <>
Does anyone know the basic command line to run a game from TecknoParrot 1.33, I can then do the rest in Attractmode.
POOTERMAN
  • Last login:March 15, 2025, 05:41:08 pm
    • My PC Desktop Icon Atwork
Re: Sega Rally 3 Command Line
« Reply #1 on: February 02, 2018, 09:00:25 am »
Try this:
"TeknoParrotUi.exe" --profile=sr3.xml
  • Last login:July 02, 2025, 09:03:11 pm
« Reply #2 on: February 02, 2018, 11:15:15 am »
off topic, but pooterman, your avatar always makes me smile.
RetroRacer
« Reply #3 on: February 02, 2018, 11:55:59 am »
Thanks dude...works like a charm.
As my kids would say....'You're a G'
Guess thats a good thing!
MrThunderwing
  • Last login:Yesterday at 05:27:58 pm
  • As I pass, do I give you the ass or the crotch?
« Reply #4 on: February 02, 2018, 07:32:22 pm »
His theme tune's even better:
POOTERMAN
« Reply #5 on: February 03, 2018, 03:31:45 am »
If you were born in the UK in the 1970's then you may well remember this too :)
Let's call it a tribute mash-up!
https://www.youtube.com/watch?time_continue=28&v=o77C9epx-VM
Friko
  • Last login:June 11, 2020, 11:57:00 am
« Reply #6 on: April 01, 2018, 08:47:29 pm »
Did anyone try this recently? I can't get it to work.
The TeknoParrot interface windows loads up with a white screen (no content) when I try
"TeknoParrotUI.exe" --profile=SR3.xml
MrThunderwing
« Reply #7 on: April 01, 2018, 09:31:03 pm »
This has nothing to do with Mr Benn! Oh wait.. I possibly might be getting my arcade forum priorities wrong here...
buttersoft
  • Last login:Yesterday at 09:26:29 pm
  • Is running at 15kHz
« Reply #8 on: April 03, 2018, 08:17:17 pm »
Does the game run fine when you open teknoparrtui.exe and then SR3? Either way, try setting up TP again from scratch. As in, wipe your TP folder but keep your SR3 folder (though you should delete the teknoparrot.ini file under the SR3/rally directory, i think it is).
Friko
« Reply #9 on: April 08, 2018, 07:22:36 am »
Thanks, that worked :)
