Author Topic: Embarrassing Problem  (Read 2385 times)
IronStrike
  • Last login:February 06, 2018, 07:32:24 pm
« on: January 31, 2018, 11:48:42 pm »
Its been years since I purchased what I needed to make an arcade cabinet. Today I actually have time to muddle around and I had a Daisy Chain Ground harness that came with an Ultimarc purchase I made.
Well...I put one end on the microswitch connector and when I went to remove it, it was stuck.  I don't want to pull to hard and rip it. So my embarrassing question is, how do I remove it without damaging the wires?
Feel free to laugh at me :(
paigeoliver
  • Awesome face!
Re: Embarrassing Problem
« Reply #1 on: January 31, 2018, 11:58:18 pm »
Grab the metal of the connector with some sort of clamping tool and pull it out that way. Don't pull it by the wire.
IronStrike
« Reply #2 on: February 01, 2018, 12:04:00 am »
Worked, ruined the switch though haha thanks :)
JDFan
« Reply #3 on: February 01, 2018, 12:17:32 am »
A bit late at this point - but if it is that tight you can use a small nail or similar to insert in the rounded part of the connector to lift it up and loosen the connection before pulling !
