Author Topic: Nooby needs some help with Retropie  (Read 5878 times)
DFW2017
  • Last login:December 30, 2017, 09:26:47 am
« on: December 29, 2017, 03:57:40 pm »
I've searched as best I can, and it has gotten me this far. However, I'm running into a few issues and can't see to locate the answers I need.  Thus, here is my situation:
I have installed Retropie, and it boots fine.  The system does not recognize my custom CP, so I hold a button and walk through the Player 1 side. Oddly, this happens every time I turn on the RPi. Question 1: Is that normal?
Question 2: How do I program Player 2 controls?  If editing of a file is required, please spell it out as in great detail as I feel like I'm already in the deep end!
I have some ROMs, and copied them to a USB. I inserted said USB into the RPi, and fired it up.  I waited a while, turned the system off and removed the USB.  Fired the system back up and Emulation Station did not show any Emulators and/or Games.
Question 3: Did I do something wrong in the ROM copying process?
Question 4: Can I copy one ROM at a time, or do I need to copy a .zip/.rar massive file with many ROMs inside?
I'm sure I'll have more questions, but those should get me started.  Thanks!
Titchgamer
Re: Nooby needs some help with Retropie
« Reply #1 on: December 29, 2017, 04:39:07 pm »
How is your cp conected? What encoder are you using?
As for the roms I always copy them over the network its much quicker and easier!
DFW2017
« Reply #2 on: December 29, 2017, 05:04:23 pm »
CP buttons and joysticks connected to an ipac2, which is connected to the Pi via the USB cable.
I would prefer the USB transfer method. Am I doing it wrong?
DFW2017
« Reply #3 on: December 29, 2017, 10:57:21 pm »
I ended up transferring the files via wifi.
Now I just need help having the Player 2 joystick and buttons recognized.  Any suggestions?
barrymossel
  • Last login:October 29, 2021, 11:25:52 am
  • Spectrum
« Reply #4 on: December 30, 2017, 04:07:51 am »
Format a USB stick to FAT32 and create a folder 'retropie'. Then plug it in the RPi and wait a short while. Then plug the USB stick back in your computer and place the ROMs in the right folder under /retropie/roms/[specific-emulator]. Then plug the stick back in the RPi.
https://github.com/retropie/retropie-setup/wiki/Transferring-Roms
You can also run the files from the USB stick. Why & how: https://github.com/RetroPie/RetroPie-Setup/wiki/Running-ROMs-from-a-USB-drive
Regarding your ipac issues, check this: https://retropie.org.uk/forum/topic/13585/ipac2-player-2-question/2
DFW2017
« Reply #5 on: December 30, 2017, 06:59:12 am »
Thanks for the links.
If I configure my CP as follows, would I need to define 1B, 2A, 2B if I wanted to use them as admin buttons? Or would they functions as such by default? I would have to add them to the CP,but better to do it now then later!
input_player1_a = alt
input_player1_b = ctrl
input_player1_y = shift
input_player1_x = space
input_player1_start = num1
input_player1_select = num5
input_player1_l = z
input_player1_r = x
input_player1_left = left
input_player1_right = right
input_player1_up = up
input_player1_down = down
input_player2_a = s
input_player2_b = a
input_player2_y = w
input_player2_x = q
input_player2_start = num2
input_player2_select = num6
input_player2_l = i
input_player2_r = k
input_player2_left = d
input_player2_right = g
input_player2_up = r
input_player2_down = f
Thanks again
Titchgamer
« Reply #6 on: December 30, 2017, 03:08:05 pm »
No buttons work by default in retropie.
You have to configure them all in ES or retroarch.
If you need to set special admin functions you will have to do that in the retroarch back end.
ivwshane
    • My first mame cab! (WIP)
« Reply #7 on: January 04, 2018, 07:50:39 am »
As far as I'm aware there is no auto copy function from USB to the pi's memory card (although I wish their was). Inserting the USB in to the pi simply tells the pi that there are games on the USB stick and after its done getting the relevant information and it reboots you will have an updated games list. You are essentially playing from the USB drive now.
barrymossel
  • Spectrum
« Reply #8 on: January 04, 2018, 09:35:28 am »
https://github.com/RetroPie/RetroPie-Setup/wiki/Transferring-Roms vs https://github.com/RetroPie/RetroPie-Setup/wiki/Running-ROMs-from-a-USB-drive
I thought the first was to physically transfer the roms from USB to RPi. The second one indeed it to run them from USB. Difference between the two is /retropie vs /retropie-mount. Never tested it with the first in a long while though.
JDFan
« Reply #9 on: January 04, 2018, 09:41:25 am »
Actually it does automatically check and copy any roms it finds on the USB stick in the retropie/roms /etc sub-folders that are different from the ones already uploaded - so by placing the roms on the USB stick and plugging the USB into the RPI - it checks for newly added files in the roims folders and will auto sync the files to the rpi's sd card. ( it does not delete any that are on the pi and not on the usb stick but does copy any that are on the USB stick but not yet on the pi.)
ivwshane
« Reply #10 on: January 04, 2018, 03:06:22 pm »
Interesting. It didn't do that the last time I tried it. I'm using recalbox so I wonder if that is the issue.
proplayer77
  • Last login:November 09, 2019, 03:23:58 pm
« Reply #11 on: January 05, 2018, 06:28:47 am »
This is true. It copies them BUT you have to wait some time if you transfer a lot of files. Plug the USB drive, and let the console be on for a while, If you try to restart it it will show some roms at the time, so take your time and just wait. Then restart Emulationstation and you should see all roms.
I did this 2 weeks ago as my sd card corrupted and i installed a fresh Retropie.
