Author Topic: reasonable replacement for Cherry p163 (atari cone button)  (Read 4424 times)
loupg
  • Last login:December 26, 2021, 06:20:34 pm
« on: December 28, 2017, 04:51:46 pm »
Is there a semi-reasonable replacement for the pushbutton that fit in the atari cone buttons?  I can buy replica cone bezels all day long, but I'm not seeing anything claiming to be a replacement pushbutton.
I don't really care if it lights up, or even looks 100% original, just looking for something that would properly fit the cone bezel.
Re: reasonable replacement for Cherry p163 (atari cone button)
« Reply #1 on: December 28, 2017, 06:15:24 pm »
Very hard to find unless they are used.  However, I did some Googling and came across this guy who made his own.  Maybe you can ask him?  https://www.rototron.info/projects/rgb-volcano-switches/
DeL
  • Last login:Today at 02:22:32 am
« Reply #2 on: December 28, 2017, 10:17:23 pm »
Since you don't care about the LED, check out this thread.
If you want an LED button, you can design and 3D print the cone, a hollow threaded shaft, and a nut for this LED/switch.
- Solder wires on the switch and insert it into the hollow threaded shaft.
- Threads on the shaft engage with threads on the inside of the cone and the nut works like any pushbutton nut.
loupg
« Reply #3 on: December 29, 2017, 07:10:13 am »
Awesome, thank you PL1, exactly what I was looking for!
850
  • Last login:September 20, 2018, 07:48:01 pm
« Reply #4 on: July 16, 2018, 06:34:29 pm »
Can you post the Mouser part number for that switch? The link no longer works.
« Reply #5 on: July 16, 2018, 09:22:43 pm »
The part number is R13-548AL-05-BRR, but Mouser doesn't have them in stock any more -- minimum order quantity is 2,000.   :o
So far, haven't found any other vendors for that 548AL switch.  :(
R13-529AL-05-BRR might be a somewhat suitable option, but it is a different size.
- 6mm plunger instead of 8.2mm on the 548
- 9mm body instead of 11.9mm on the 548
Swatee Electronics has them here.
Another possible option is an R13-508AL-05-BRR-L3, but it has a square bezel and has a much larger diameter plunger.
If you find a vendor stocking the 548AL's or a better substitute, let us know.   :cheers:
« Last Edit: July 16, 2018, 09:26:05 pm by PL1 »
