Author Topic: San Francisco Rush: The Rock working in MAME 0.193  (Read 11953 times)
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
« on: December 27, 2017, 08:32:29 pm »
Just a heads up, San Francisco Rush: The Rock - Alcatraz Edition is now working in MAME 0.193. Hopefully 2018 can bring some improvements to 2049.
isamu
  • Last login:February 19, 2026, 01:09:24 pm
Re: San Francisco Rush: The Rock working in MAME 0.193
« Reply #1 on: December 27, 2017, 08:47:08 pm »
I thought all the SF games were already working in MAME? This is interesting.
VirtuaIceMan
  • Last login:September 09, 2025, 07:52:27 am
« Reply #2 on: December 27, 2017, 08:58:58 pm »
That's cool; it can now be compared to the two PC ports!
Check out my racing game videos, including every PC F1 and Rally game ever, over here: https://www.youtube.com/user/VirtuaIceMan/
DarthMarino
« Reply #3 on: December 27, 2017, 09:08:55 pm »
Only the original has been fully working.
isamu
« Reply #4 on: December 28, 2017, 10:23:48 am »
cool :)
VirtuaIceMan
« Reply #5 on: December 28, 2017, 09:17:57 pm »
Looking at Haze's writeup, apart from Rush The Rock, Cruis’n Exotica is improved (not perfect yet), CART Fury is playable and San Francisco Rush 2049 - Tournament Edition can be played to a point: https://mamedev.emulab.it/haze/2017-new-focus/
isamu
« Reply #6 on: December 29, 2017, 10:43:39 am »
Cool. What framerate do these Atari/Midway games natively run at?
VirtuaIceMan
« Reply #7 on: December 29, 2017, 03:37:20 pm »
my MAME is still on 0.188 lol, not had time to upgrade it yet.
Update: Just tried, they say 100% on my 4790K, but unless they only ran at 15-30fps there's something not quite right!
« Last Edit: December 29, 2017, 09:34:57 pm by VirtuaIceMan »
isamu
« Reply #8 on: December 30, 2017, 10:30:35 pm »
Pretty sure the games in the arcade actually ran at 30fps. So maybe your 4790K is slightly underpowered if you're seeing dips to 15fps. Also, you mentioned SF 2049 Tournament Edition, but what about the normal version of 2049? Is it supposed be working or still broken? You tried it yet? I'm at work and In the middle on adding shortcuts to my steam library but will try them when I get to the house.
VirtuaIceMan
« Reply #9 on: December 31, 2017, 05:17:23 am »
Haze said this: San Francisco Rush 2049 – Tournament Edition also improved, and can be played to a point, but is still marked as NOT WORKING. The non-tournament edition crashes when it reaches the title screen or if you attempt to start a game.
isamu
« Reply #10 on: December 31, 2017, 12:15:47 pm »
Gotcha. Thanks. Hopefully in the next revision  :cheers:
rocomat
  • Last login:November 25, 2019, 12:10:13 pm
« Reply #11 on: January 18, 2018, 09:19:36 pm »
runs fine in 0.191, perhaps in earlier versions, too.
Only difference, game is marked as "good & running" since 0.193...
!! Looking for After Burner Deluxe cabinet plastic parts !!
DarthMarino
« Reply #12 on: January 23, 2018, 06:31:43 pm »
I can't get past the track select screen on 0.191....
DarthMarino
« Reply #13 on: January 01, 2019, 09:37:04 pm »
As of today San Francisco Rush 2049: Special Edition is playable in MAME.  It's actually worked for a while but the sound would stop working shortly after you start playing.  I have played it for a few yours tonight and have had no issues with the sound.
DarthMarino
« Reply #14 on: February 04, 2019, 12:46:31 pm »
The hard drive that was dumped for 2049 Special Edition had many accounts built in.  If you use the pin number 007007007 you will access the account of the person who dumped that drive.  He has all of the paint jobs unlocked including ones you can only get by winning races when the machines are linked.
