Author Topic: [APP] TypeXtra - Taito TypeX + Nesica Launcher  (Read 5869 times)
stigzler
    • Mago Arcade
« on: December 12, 2017, 04:54:18 pm »
    Overview
    TypeXtra was designed to make setting up TypeX and Nesica Systems more straightforward. There are lots of different game sets out in the wild, so setup can be quite a confusing job. This aims to make it a few clicks job. TypeXtra does not come with any "ROMS." That would be illegal. If you own the system you are aiming to emulate, then you can secure a "ROM" image of the game to emulate on your PC.
    Once you have the ROM/s you want, TypeXtra aims to make setup a 3 step process:
    - Point it to the directory/s in which your ROM/s reside
    - Click "Autoscan." It will automatically identify most games if their folders contain a game.inf file (some roms don't)
    - Click "Setup Games" to install an assured set of support files which will make the game run. This does depend on your ROM files.[/li][/list]
    Features
    - Import other "Game Service" sets - ones that are designed to ensure games boot OK. Some of these have modified game executables, therefore they're not included with this distribution. However, see elsewhere for instructions on obtaining and importing.
    - Import "HD Exe" sets. The original game executables ran at lower resolutions. Some modified executables have been produced to have these games work at higher resolutions (not just stetch to fill your display, but to actually render at higher resolutions).
    - Customise what files launch the game, what file to monitor for the game ending and what controls setting application to use on a game-per-game basis.
    - Runs invisibly from command line - once you have your games set up, send it the short ort long game name and it will boot the game and close itself once the game executable has stopped. This helps with front end setups, where the front end will monitor for the temrination of the launch application (in this case, TypeXtra).
    - Create shortcuts pointing towards the game launch files in either the 'long' or 'short' game format. This can be used to have a front end launch a file directly by executing the shortcut, or, more helpfully, get the correct command line parameter to pass to TypeXtra to launch the game.
    - Audits the exe files and compares against a database of known working vs known rubbish roms (database in early stages)
    Screenshot
    Video
    Download and further info
    https://sites.google.com/view/magoarcade/software/typextra
    Forum and Bug Reports
    Forum: http://retrorigs.biz/MagoForums/index.php?board=13.0
    Bugs/suggesitons: http://retrorigs.biz/Mantis/
    « Last Edit: December 12, 2017, 04:59:34 pm by stigzler »
