Author Topic: arecadeshop.com vs escapepodonline.com for artwork  (Read 5295 times)
loupg
  • Last login:December 26, 2021, 06:20:34 pm
« on: December 12, 2017, 09:19:49 am »
I'm planning to make a defender cabinet as a MAME/multicade cabinet.  I'm planning to use the defender artwork and am currently looking at both escapepodonline.com and arcadeshop.com.  arcadeshop.com doesn't have a defender marquee, but does have the side art, monitor bezel and control panel, escapepodonline.com has all of the pieces.
From what I'm seeing, it appears escapepodonline.com costs about $100 more for the pieces that arcadeshop.com carries.  I'm considering buying most of the artwork from arcadeshop.com and just getting the marquee from escapepodonline.com, or potentially sourcing the marquee from ebay, but I was wondering if there was anything I should be aware of that would account for the $100 price difference between the two shops.
8BitMonk
Re: arecadeshop.com vs escapepodonline.com for artwork
« Reply #1 on: December 12, 2017, 03:43:45 pm »
Stencils or GTFO. :lol  No, seriously though... from thisoldgame.com: https://www.thisoldgame.com/stencils/defender-stencil-set
loupg
« Reply #2 on: December 12, 2017, 03:52:11 pm »
I have thought about going the stencil route, but my two concerns are 1.) how much monkeying around I'll need to do to get reasonably close colors, and 2.) that does require me to actually get the stencils lined up with each other, while vinyl allows me to just be reasonably close for the entire side of the cabinet.
8BitMonk
« Reply #3 on: December 12, 2017, 05:45:27 pm »
The color match is pretty simple, Rustoleum Satin Black, Krylon Red Pepper and Krylon Sun Yellow. That'll get you as close (or probably closer) than the vinyl will. Of the different stencil types Defender is probably one of the easier ones to apply but yeah it's definitely more work than vinyl, although it's then also more original looking and unique.
You can see the colors used on GearHead's excellent restoration thread here: http://forum.arcadecontrols.com/index.php?topic=150817.0
loupg
« Reply #4 on: December 12, 2017, 06:17:08 pm »
Ooh, thanks for the link to the restore thread!
So, other than the side art, any advice on the control panel overlay?  Are they essentially going to be the same from all three sites?  I'd read escapepodonline does inkjet printing, I believe arcadeshop states theirs is screen printed, thisoldgame states solvent printed on the defender overlay, but says printed at the time of order for the multi-williams overlay, which I'm guessing means it's likely inkjet for that specific overlay.
I like that thisoldgame prints their monitor bezel on tempered glass, so I think I'll go with their bezel.
Does escapepod do a good job with their marquees?
8BitMonk
« Reply #5 on: December 14, 2017, 10:18:25 am »
Thisoldgame does really good work, that'd be your safest bet though they tend to take a little extra time. I don't care for the inkjet repro marquees, I'll typically look for an original in decent shape first. Just depends on how picky you are, if you're ok with vinyl for the side art then a repro marquee from a reputable vendor would probably be fine.
