Author Topic: Wire TV Power Button  (Read 2847 times)
Haloman800
  • Last login:February 07, 2020, 12:40:00 am
  • Awfully Awesome
« on: December 05, 2017, 01:28:01 am »
I am looking at a 19 inch TV for a project (converting a plug & play), I wanted to see if anyone here has wired an external power button to a TV.
The goal is to power everything with one switch/button.
Here's the TV I'm looking at https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F292356546939
Sent from my SM-N950U using Tapatalk
lilshawn
  • Last login:Yesterday at 06:22:50 pm
Re: Wire TV Power Button
« Reply #1 on: December 15, 2017, 03:28:05 pm »
hold the power button down and plug in the set. if it powers on, short the power button and call it good.
if it won't turn on when plugged in, try placing a 100 or 200uF (16 volts or higher) capacitor across the power button contacts. you will have to measure to see which contact is supplying the 5 som odd volts used to sense the button press and put your + lead of the capacitor on that lead.
that capacitor will act as a short on the button but "look" as open once the capacitor charges up from the 5 volts, essentially acting like a button press.
some TV's will just power on again if powered off while they are active. you may not need to do anything.
Slippyblade
« Reply #2 on: December 15, 2017, 03:36:58 pm »
That capacitor trick is awesome, never thought about that.
lilshawn
« Reply #3 on: December 15, 2017, 05:45:56 pm »
There is a thread here somewhere that outlines pretty specifically how to wire it up.
I've used the capacitor trick with computers as well to power them on even if the "power on after AC loss" setting is on in the BIOS, but for some reason it still doesn't boot. (common with the big buck hunter PRO computers.)
