Author Topic: Outrun 2 FXT 2.5 Released!  (Read 241044 times)
insx
  • Last login:August 16, 2025, 06:17:23 pm
  • I dabble in Retropie and virtual pinball
Re: Outrun 2 FXT 2.5 Released!
« Reply #280 on: July 02, 2024, 11:17:17 am »
I'm finding the wheel config tweaks a bit daunting, is there a way to make the wheel feel generally heavier? Also, I'd like to decrease the constant rumble over wet or icy roads.
If you don't see an option there, then no, sadly.
After a bit of digging, I found that using a high number (8000 ish) for tweaks 5 and 6 adds a fair bit of spring strength and IMO makes the wheel feel a lot better. I think reducing the effects of wet/icy roads is maybe not possible without reducing all the other effects.
Habanero
  • Last login:October 01, 2024, 12:24:22 pm
« Reply #281 on: July 15, 2024, 07:05:30 pm »
Does LAN multiplayer work for anyone else if you're using Radmin or Hamachi? I just tried it and we couldn't find each other's in-game lobbies. We were able to join the same Radmin server, but that's as far as we got.
cangarujack
  • Last login:November 04, 2025, 04:32:00 am
« Reply #282 on: October 06, 2024, 08:52:32 pm »
Hello Howard_Casto,
I think you know the recent Outrun tweaks...
Unfortunately it doesn't support FFB. Could you do it?
Arnold101
  • Last login:June 19, 2025, 01:56:35 am
« Reply #283 on: June 06, 2025, 01:13:16 pm »
Hello Howard_Casto,
agree.
need help please, when using wheel g29 and its 6 manual shifter, the 3 and 4 gear make the car turn left and right, i have really no clue on how to fix it, any help please? thanks a lot
also i can't find any fxt 2.5 download, someone can upload it here please?
Arnold101
« Reply #284 on: June 10, 2025, 04:44:55 am »
help ::)
buttersoft
  • Last login:Today at 05:07:41 pm
  • Is running at 15kHz
« Reply #285 on: June 10, 2025, 05:52:19 am »
Hmm, the Dragonking site is up, but the download link is broken...
I seem to have a copy, and have uploaded it here for you - https://fastupload.io/e31dd2ba56792387
Arnold101
« Reply #286 on: June 10, 2025, 06:44:16 pm »
thanks a lot man, any idea on how to fix logitech g29 manual shifter that on gear 3 and 4 make the car turn? :/ only with this game
buttersoft
« Reply #287 on: June 10, 2025, 07:17:19 pm »
Not specifically, no. I can tell you that this game has a few control issues, and the FXT wrapper fixes... some of them. if you can, only plug in you G29, no other controllers. I would then try different combinations of rebinding controls in-game and in the wrapper, calibrating the wheel both in-game and in windows, and enabling or disabling the FXT control override - i never wanted to use it as it won't let you gear-drift.
While this mod is awesome, i prefer OR2 SP SDX in Teknoparrot, myself.
Arnold101
« Reply #288 on: June 11, 2025, 06:24:15 am »
why?
  • Last login:Today at 02:35:08 pm
« Reply #289 on: June 11, 2025, 01:57:19 pm »
Looks like the http://dragonking.arcadecontrols.com/simplephp/ccount/click.php?id=80 link is not redirecting to the correct URL.
- Same thing happens with a number of similar links on the site.
You can usually find the correct URL by plugging the link into archive.org to find an older version of the site where the redirect was working correctly.
That link redirects to this download link on archive.org . . .
https://web.archive.org/web/20210603121106/http://dragonking.arcadecontrols.com/files/OR2FXT2.5.rar
. . . that ends with this direct download from DragonKing link . . .
. . . that also works as an https link.
https://dragonking.arcadecontrols.com/files/OR2FXT2.5.rar
  • Last login:January 17, 2026, 03:40:02 pm
« Reply #290 on: June 11, 2025, 09:00:41 pm »
The download counter I have set up occasionally destroys itself causing the links to break.   The site really needs to be overhauled but I never have the time.   I think I'm just going to add files here on the forums in the future.
buttersoft
« Reply #291 on: June 11, 2025, 10:03:39 pm »
That does seem convoluted :)
why?
Well, the mod does have options like the stage editor (changes order of stages around) but i'm running side-by-side sit-down setups, and booting right into LAN is much better for me, even if it''s missing some of the content. I'm also on CRT's, so i don't need any texture upgrades. And despite all the graphical fixes, i still say the arcade versions look better.
« Reply #292 on: June 12, 2025, 05:22:01 am »
True.  Just laying out a trail of breadcrumbs that can help people find the files they want/need.   :cheers:
BTW, the same approach works with some sites that are up but not working right, such as Mr. Do's Artwork hosted over at MAMEWorld.
https://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=400564&page=0&view=expanded&sb=5&o=&vc=1
Anyway, the site is old and unmaintained, and doesn’t work with new versions of PHP. An overdue server update broke the crusty old code. There’s no-one left to fix it.
- The old version of PHP that they're using no longer displays the list of art .zip file links, but you can get download links from the archived page here.
- Even if archive.org hasn't archived the file, you can copy/paste the "https://mrdo.mameworld.info/artwork/...zip" part of the link URL into your browser to snag the desired file from the MAMEWorld servers.   ;D
Arnold101
« Reply #293 on: June 13, 2025, 02:50:24 pm »
this is my config is correct or not? i don't know what are this keys...
« Last Edit: June 13, 2025, 03:33:13 pm by Arnold101 »
« Reply #294 on: June 13, 2025, 03:08:44 pm »
Sounds like you might have num lock turned on.  Otherwise I’m not sure.
Arnold101
« Reply #295 on: June 13, 2025, 03:31:58 pm »
turned off, same thing  :'( :'( :'( :'( :cry:
ok i solved it: created a new profile for the game in logitech g hub, put key 3 and 4 on gears 3 and 4. In the mod config delete input for 3 and 4 gear, up on key window put button 3 and 4 of keyboard on 3-4 gear, works perfectly
i need an advice on how to calibrate the wheel in the game. when it ask to turn the wheel to the left and press button i need to keep the wheel turned and press button or i can turn the wheel to the left and then release it and press button? because sometimes when in the game i make turns quickly from left to right and viceversa the controls got grazy.
« Last Edit: June 13, 2025, 06:37:00 pm by Arnold101 »
