Author Topic: rowe r88  (Read 2840 times)
jimsinn
  • Last login:November 30, 2017, 09:11:34 am
rowe r88
« on: November 27, 2017, 11:40:15 am »
Hi Newbie to forum,
Brother just acquired r-88 jukebox, switched on,all neon tubes light but nothing happens.
Bought  service manual but no information ie circuit diagrams on mechanic  board or ccc board.
check amp ok.
power supply all three leds lit.
ccc 8 volt led not lit but have checked and 8volts supplied to board.
I am a retired IT support engineed with an electronic servicing background and suspect faulty
ccc board but with no access to circuit diagramhave no way to try and fault find.
any help would be really appreciated.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: rowe r88
« Reply #1 on: November 28, 2017, 09:45:12 am »
Hello jimsinn,
Welcome to the forum.
I would check out the voltages AC and DC at the service switch and to the 9 pin connector on the left hand side of the mechanism frame.
If these are still ok then you would be better off sending the following boards to a Rowe Ami specialist for testing/repair:-
CCC
Mechanism control
Pricing Board
Regards
Alan
Alan Hood
ami-man
UK
jimsinn
Re: rowe r88
« Reply #2 on: November 28, 2017, 12:00:02 pm »
thanks for reply,
will check as suggested.
if needed do you know of specialist who would check/repair boards and
any idea of costs
thank you again
jim
ami-man
Re: rowe r88
« Reply #3 on: November 29, 2017, 05:44:14 am »
Hello Jim,
In the USA is Bruce Wentworth of AB Leisure and myself in Europe.
Regards
Alan
Alan Hood
ami-man
UK
