Author Topic: electrical question here  (Read 822 times)
menace
« on: January 31, 2004, 11:21:27 am »
How do I step a pc 5V supply down to 3V?  thanks.
LoRDDeVO
  • Last login:January 06, 2023, 01:27:54 pm
  • 80's retrotechnoelectrogeek
Re:electrical question here
« Reply #1 on: January 31, 2004, 02:57:27 pm »
you can always use a resistor to drop volatge or a zener diode to give you exactly 3V problem with these solutions are they get very hot if you have a big load on the other end
menace
« Reply #2 on: January 31, 2004, 03:09:33 pm »
Thanks!--I should have mentioned that I was driving 1 amplified speaker--you know the el-cheapo kind that plug into each other and then into the pc.  I wonder if i could just run it at 5v--do you think it would get too hot?
Druin
  • Last login:May 10, 2009, 02:30:37 am
« Reply #3 on: January 31, 2004, 03:46:38 pm »
String a bunch of diodes in series with the 5volt supply, each one will drop it down a bit.  I think I tried this a few days ago and saw 0.3volts dropped for each diode I added, so if you string 6 or 7 general purpose diodes in series you may get 3volts out.
