Author Topic: Have OLD roms (0.36)... looking for Ubuntu-compatible version of MAME  (Read 11603 times)
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
I found SDLMame, but I don't know if they have versions of the executable that would work with my ancient ROMs.
(I am using a very old laptop and had to install Ubuntu on it; nothing else would work. I haven't updated my ROMs in about, oh, 10 years or so?)
Where can I get a Ubuntu version of MAME? Thanks.
Locke141
  • Never grow up.
Re: Have OLD roms (0.36)... looking for Ubuntu-compatible version of MAME
« Reply #1 on: November 20, 2017, 10:55:52 pm »
If I was you I would go find a newer used computer and a newer set of rom's. You should be able to find both for free. Check crigslist or Goodwill for a new old PC and get ubuntu and Attract mode. Just google for a newer rom set.
I would definitely not even try to do the following, as it would be a lot more work, I'm not even 100% sure how to do it, and it would be much harder then what I suggested above. But if you really want to stick with what you have then FreeDOS may be a better OS for this. Get the old 0.36 MAME for DOS from here, and you could probably get an old DOS FE like Advancemame or ArcadeOS. Again, this is a really bad idea, and it would be a lot of work for something out of date and worse in ever way.
« Last Edit: November 20, 2017, 11:12:24 pm by Locke141 »
loupg
  • Last login:December 26, 2021, 06:20:34 pm
« Reply #2 on: December 21, 2017, 12:19:45 am »
Here's a link to the MAME 0.36 source: https://mirrors.xmission.com/mame/releases/mame036s.zip
I've not tried to compile it from source, so I'm not sure what issues you might run into, but that would likely be your only way to get 0.36 running in Ubuntu.
Robbbert
  • Last login:December 10, 2025, 06:11:05 pm
« Reply #3 on: December 21, 2017, 04:55:02 pm »
That laptop would have to be really ancient to not be able to run Windows. I've got something from last century and it runs Windows 2000 Pro just fine, which doesn't require validation, and will run MAME up to 0.169 . XP would be better of course, since even the latest MAME will work on it.
