Author Topic: Ultimarc LED wire help  (Read 1763 times)
arcadejuinkie
  • Last login:January 15, 2025, 02:47:34 am
« on: November 18, 2017, 06:52:40 pm »
Ok so I abandoned my previous setup that came as I bought it on my gpwiz40 as the previous owner wired it so bassackwards that I just went ultimate i/o route. When i’m Wiring up the black connector to the end of the r/g/b/y wires I see the triangle so is that where yellow wire goes?  If so what is the order from there for the r/g/b wired?  If there is a link or something I can be pointed to that works too.
TIA!!
« Last Edit: November 18, 2017, 07:35:53 pm by arcadejuinkie »
gumby510
  • Last login:November 17, 2022, 09:19:44 pm
  • SR-20 NX 2000
Re: Ultimarc LED wire help
« Reply #1 on: November 18, 2017, 11:44:34 pm »
The order is printed right on the board
arcadejuinkie
« Reply #2 on: November 19, 2017, 12:38:43 am »
So the + sign is the yellow wire then?  Wow. I was way over thinking things lol
Titchgamer
« Reply #3 on: November 19, 2017, 01:28:52 am »
Yep,
RGB red green blue wires.
Then the yellow :)
