Author Topic: Progress pics of my first 'cab so far, advice, suggestions, anything etc  (Read 4286 times)
paradoxum
  • Last login:February 16, 2019, 12:35:40 pm
https://imgur.com/a/dq087
Was going to use a 19" monitor but found that to be too small, bought a 22" 16:10 ratio instead and will be using that.
Going to have a power strip on the inside wired up to one of these and plug everyhing into the power strip internally, the RPi will plug into a USB-DC power plug on the adapter, aswell as the marquee light and anything else needing USB power.
The audio amp is going to be plugged into that too with this, plugged into the internal power strip, and I'm going to power the fans via the USB-out on the amp (usb-to-molex cables). Or could just use another usb powerered hub.
Any advice for what I'm doing? anything to make it easier etc. Trying to reduce the amount of cable splitting / soldering as much as possible because I'm not confident enough in my soldering / electronic skills to not blow something / burn the place down, plus being a perfectionist I want things as neat and tidy as possible.
The art I've got coming looks like this, what i'm roughly aiming for:
« Last Edit: November 08, 2017, 09:19:55 pm by paradoxum »
zinger
  • Last login:February 25, 2019, 05:09:31 pm
  • There's a Donkey Kong Kill Screen coming up!
Re: Progress pics of my first 'cab so far, advice, suggestions, anything etc
« Reply #1 on: November 09, 2017, 01:34:29 am »
Looks good. Although, I'm not sure why you need the 9-12V 5A breakout cable. Audio amps typically use 12V but you mention powering everything off USB which is 5V 500mA.
Also, was shocked to see Wolverine in the reflection.
paradoxum
« Reply #2 on: November 09, 2017, 11:56:15 am »
Heh! I have been having to put some oil stuff on my neck to heal a burn and it stains t-shirts.
I got the rest of the electronics stuff today (everything sans buttons/sticks), laid it out, does this look like it'll work? Anything I might be missing here etc?
Drew some lines to try show the connections. Not sure how much it'll help.
I think everything looks in order, although I'm a bit confused as to how the speakers are going to recieve audio - they only have +/- connections on them, for power? Which I guess i'll wire into that green-tipped jack connected to the Amps power supply, and the RPi audio cable goes from RPi -> AMP, but how does the audio get to the speakers? I must be missing a cable somewhere or something.
Edit: looks like maybe the wires from the speakers just slot into these clamp-type connectors on the amp?
https://imgur.com/a/OnewE
then audio in however you like from the Pi?
« Last Edit: November 09, 2017, 12:46:55 pm by paradoxum »
yamatetsu
  • Last login:Today at 04:42:12 pm
  • Just because.
« Reply #3 on: November 10, 2017, 12:57:23 am »
Yep, that's it. Just connect + from the speaker to the + slot on the amp, and - to -.
paradoxum
« Reply #4 on: November 10, 2017, 06:47:24 am »
Thanks, seemed like how to do it but didn't want to blow anything up when I turned it on etc.
barrymossel
  • Last login:October 29, 2021, 11:25:52 am
  • Spectrum
« Reply #5 on: November 10, 2017, 01:12:30 pm »
I am glad you didn't "power" the speakers...
paradoxum
