Author Topic: Different Computers - Question  (Read 3447 times)
floyd68
  • Last login:August 19, 2021, 02:06:00 pm
« on: November 05, 2017, 03:23:15 pm »
Folks,
I have two computers running MAME.
My home computer and my arcade cabinet.
What I find is I can run certain games on my home computer that are KILLING my arcade cabinet.
GAME HOME COMPUTER ARCADE CAB
NFL BLITZ Perfect Stuttering, unplayable
MORTAL KOMBAT Perfect Slow
I know my two computers are different, but I can't believe the HOW different MAME works between the two of them.
Here are my stats:
Home Computer
* Windows 10
* CPU - Intel Core i3 6100 @ 3.70GHz
* RAM - 16.0 Dual @ 1066MHz
* MB - ASRock Z170 K4
* Graphics - 2047MB NVIDIA GeForce GTX 750 Ti
Arcade Computer
* Windows 7 32-bit
* CPU - Intel Core 2 Duo E8500 @ 3.16GHz
* RAM - 4.0 Dual DDR2 @ 400MHz
* MB - EVGA 122-CK-NF68
* Graphics - 256MB NVIDIA GeForce 7600 GT
What is the average computer / computing power I need to run NFL Blitz and other intensive games?
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
Re: Different Computers - Question
« Reply #1 on: November 05, 2017, 03:48:24 pm »
There is a huge difference between that (6th gen?) i3 and the core 2 duo. I have i3 processors in both my MAME cabs which perform really well, but wouldn't want to go any lower.
floyd68
« Reply #2 on: November 05, 2017, 04:02:13 pm »
Looks like an eBay search is in my near future.
My wife is going to kill me.
smass
  • Last login:December 05, 2024, 06:12:33 pm
  • Cheapskate Arcade
« Reply #3 on: November 05, 2017, 04:12:06 pm »
Look for a second gen i5 - you can usually find one for well under $100 pretty easily.  Should do the trick.
paigeoliver
  • Awesome face!
« Reply #4 on: November 06, 2017, 03:40:52 pm »
You could waste money on replacing the computer or you could roll back your mame version for those 2 games until they run full speed.
Folks,
Here are my stats:
Home Computer
* Windows 10
Arcade Computer
* Windows 7 32-bit
Titchgamer
« Reply #5 on: November 06, 2017, 03:46:11 pm »
Upgrade ya GFX card and that will make a pretty hefty difference I would guess.
Ime surprised you are running 32bit though, 64 would be more beneficial I would think if your hardware would support it.
Automark
  • Arcade in Spain ?
« Reply #6 on: November 08, 2017, 11:34:17 am »
We have all been there  >:D
  • Last login:February 22, 2026, 09:34:29 am
« Reply #7 on: November 08, 2017, 11:59:20 am »
huh? MAME doesn't utilize the graphics card for anything but post processing effects like HLSL.
All the 3D rendering is done by the main processor which is emulating the original hardware.
Concerning BLITZ:
On that particular hardware (vegas driver IIRC), using the 64-bit version of MAME makes a decent difference.
There are DIP switch settings in MAME's in game menu where the original arcade hardware could be set to run at a lower resolution.
Dropping it to the lower resolution helps a bit.
Also make sure HLSL is disabled.
EDIT: There's something weird going on with Mortal Kombat.  It should be full speed on both unless you are talking about MK4
DOUBLE EDIT:  I'll second paigeoliver's advice on using an older version of MAME.  I'm still at 146 on my cab because some games I like won't run at full speed if I use a newer version.
« Last Edit: November 08, 2017, 12:02:38 pm by BadMouth »
Titchgamer
« Reply #8 on: November 08, 2017, 12:02:38 pm »
MAME may not use it that much but 256mb is low even for a old PC.
Ide go 512mb minimum
I have the same processor and mine runs fine.
Ide suggest another 4gb of ram to but 32bit wouldn’t recognise it if I recall right.
« Last Edit: November 08, 2017, 12:05:16 pm by Titchgamer »
paigeoliver
  • Awesome face!
« Reply #9 on: November 09, 2017, 12:45:33 am »
Oddly enough that second 4GB of ram is not as important as you would think. I being a complete moron managed to break a couple pins off my 8 core 4GHZ processor during what was supposed to be a routine cleaning/dusting. The thing can't address the second ram slot anymore, and truthfully I can't tell. Although I am 100 percent SSD.
Also, once again, choking on Mortal Kombat is a joke. With the right Mame version it will run full speed on a 500 mhz processor.
