Author Topic: Help required please, Ducksan board  (Read 2477 times)
Dubber
  • Last login:July 27, 2018, 11:52:00 pm
« on: October 31, 2017, 10:14:42 pm »
Hello all.
First time poster but frequent visitor.
I'm working on a type 20 ducksan (old type) (thanks to Mr Layton for the guide)monitor with the intention of recapping it. However, I've run into a snag, I wanted to just replace all the caps, Lens guide of the old type 20 mentions quite a few of them but not all, and if I look at the 'new' type 20 cap list it for the most part does tie up with the old but not all. Does anyone by any chance have a cap list for the old type 20 ducksan kw 992 and the neck board.
Dub
Dubber
Re: Help required please, Ducksan board
« Reply #1 on: November 02, 2017, 12:23:36 pm »
Edit to the above post:
Looks as though I've drawn a blank on a full list of caps required for this so I'll go for a wildcard :)
This monitor is out of a megatouch encore 7, ducksan (old type) 20.  If anyone has one could they post the specs of the largest cap on the neckboard.
On the mainboard I'm pulling a few 2200mf 16v and a couple of 22mf 160v and I have no way of knowing if whoever had this previously just chucked anything in in the hope that it would work.
Cheers
grantspain
« Reply #2 on: November 02, 2017, 12:48:10 pm »
http://slot-tech.com/amusements/monitor_schematic_diagrams/ducksan_type20.jpg
10uf 160v according to the schems
how do you know its cap related, I remember working on these and there were loads of faults from ntc, bridge, lm1203, caps, hot, flyback etc
Dubber
« Reply #3 on: November 02, 2017, 03:21:28 pm »
That's looks like the 'new' type 20. Mine's got a 22mf 160v sitting in the neckboard
In reply to your question, I don't. The thing has been sitting in a dry but very hot/cold room -20 for 2 plus years and I'm guessing that's not done the caps any good so I thought I'd just start from scratch and replace them, then move on from there.
grantspain
« Reply #4 on: November 04, 2017, 09:12:30 am »
just stick the same value cap back in
