Author Topic: What FRONTEND do you use with GroovyMAME?  (Read 37236 times)
keilmillerjr
  • Web Developer.
Re: What FRONTEND do you use with GroovyMAME?
« Reply #40 on: March 08, 2019, 10:11:40 am »
I have no real issue with windows 10 @640x480. On my pi, I use ssh. Perhaps this can work with windows?
tadek
  • Last login:March 08, 2019, 10:24:59 am
« Reply #41 on: March 08, 2019, 10:25:03 am »
Don't know how Win 10 handles 640x480 res, but Win 7 is wonky. It even has a warning that any res below 1024x768 may produce problems (not all gui elements fitting/shown).
SSH is great when you connect to linux box.
I preffer RDP for Windows mashines. Can set any resolution, and it's working like siting in front of the PC.
bjt42
  • Last login:February 03, 2022, 06:24:37 am
« Reply #42 on: March 12, 2019, 06:59:11 am »
AttractMode here, works well with GroovyMame & PortAudio.
zerochad
  • Last login:January 20, 2024, 10:13:25 pm
    • C D C R U Z E
« Reply #43 on: March 12, 2019, 06:50:19 pm »
I use a smaller frontend called Big Blue.
Really lightweight, simple and easy to configure. It's not flashy or anything but I love it.
I've written some articles about it previous;y:
https://cdcruze.com/2018/03/choosing-the-right-frontend-that-isnt-hyperspin/
https://cdcruze.com/2018/04/how-to-set-up-big-blue-front-end/
cdcruze.com / emulation & arcade tutorials
808state
  • Last login:March 18, 2019, 01:19:40 pm
  • Wells CRT D9800 27" Full Size HyperSpin CaB
« Reply #44 on: March 15, 2019, 07:56:07 am »
HyperSpin Here!
I notice not too many folks here are running HyperSpin...is this frontend getting played-out? I thinks the wheel Art and extra Art are prreeettty DoPe!
lolomre
  • Last login:June 03, 2022, 07:05:50 am
« Reply #45 on: May 14, 2021, 09:42:19 pm »
I NEED HELP
i have installed maximus arcade frontend in my CRT sony triniton 29" RGB SCART
my pc have graphic card ATI HD7000 and use crt emudrivers 2.0 and groovymame and cable vga-scart 15khz. my games have good scanlines, RGB..........ALL PERFECT....BUT...WHEN I WANT OUT FRONTEND MAXIMUS ARCADE......I LOSE THE signal od windows 10 IN MY CRT...AND HAVE SHUTDOWN PC. any solution?
psakhis
  • Last login:September 24, 2024, 11:54:25 am
« Reply #46 on: May 15, 2021, 03:05:35 am »
Emulationstation  :P
This fork it's great https://github.com/fabricecaruso/batocera-emulationstation.
Fullscreen is borderless so no problems with resolutions.
If you are interested i share you my theme for CRT at 450x270.
abispac
  • Last login:November 28, 2025, 07:58:36 pm
« Reply #47 on: May 15, 2021, 04:19:44 pm »
hyperspin, but is limited to 100 resolutions,so im considern emulation station,but can find a nice theme,so im sticking with hyperspin,to bad ,bad boy bill never released the source to fix such bugs.
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #48 on: May 15, 2021, 11:40:26 pm »
Launchbox/Bigbox might be good as well.. but it (premium/bigbox) costs $ so haven't tried it yet (only tried launchbox part)
« Last Edit: May 20, 2021, 07:45:30 pm by Sledge »
vagrant_17
  • Last login:June 24, 2021, 08:34:17 pm
« Reply #49 on: May 16, 2021, 07:14:31 am »
Launchbox/Bigbox is fantastic.. well worth the price 8)
mrchrister
  • Last login:November 27, 2025, 10:00:26 am
« Reply #50 on: May 17, 2021, 10:58:14 pm »
I have a Hyperspin setup with Rocketlauncher and Attract Mode with Rocketlauncher.
Hyperspin is prettier and works well for my vertical cab. Attract Mode is awesome and it's the best frontend I've used becasue everything makes sense. Without the need for a manual (like HS) I can get everything set up very quickly and it just works
burn_654
  • Last login:April 29, 2025, 04:25:44 pm
« Reply #51 on: May 18, 2021, 10:13:11 am »
I was a longtime Mala user but just unfortunately had to move on. Attractmode is fast, stable, dead simple and does exactly what I want in a crt cab - clean display with some screenshots/sample videos without feeling crazy cluttered. It can do the complex stuff too if you want it. Plugins are pretty easy to edit to do specific things for you. Bear in mind I loved Mala but by the end I was fighting more and more with focus issues in modern emulators/Steam, randomly losing focus while other people were using it (it always works perfectly until someone else uses it  ;D) I've found it far trickier for strangers to 'break' Attractmode in Windows 7 for what it's worth.
I'd encourage mala crt users to take an afternoon and try out Attractmode, I groaned and delayed and waited ('I hate change!' etc.) but I wish I did that a long time ago.
Osirus23
« Reply #52 on: July 20, 2021, 01:25:40 pm »
« Last Edit: August 23, 2021, 01:30:25 pm by Osirus23 »
