Author Topic: 'The Arcade' joystick with DB9 connector for playing on an MSX emulator  (Read 5336 times)
qxb265
  • Last login:October 20, 2017, 11:49:07 am
Hello,
I am new, so not sure where to post my question...
I want to use a retro 'The Arcade' joystick for playing on an MSX emulator. Therefor I bought a DB9 connector to connect my joystick via USB to my Mac. See the added photo. I can't get it to work. Is there something I am doing wrong or is this not gonna work....?
cheers,
qxb
  • Last login:Today at 02:45:34 am
Re: 'The Arcade' joystick with DB9 connector for playing on an MSX emulator
« Reply #1 on: October 18, 2017, 10:36:14 pm »
Welcome aboard, Qxb265.   ;D
I'm not familiar with that adapter.   :dunno
Do you have a part number/manufacturer/link for it?
Did the listing say that the adapter is intended for DB9 joystick ==> USB or is it intended for serial port ==> USB?
(There's a huge difference in the wiring between these two applications.)
If it's intended for a joystick, there should be a gamepad encoder inside.
qxb265
« Reply #2 on: October 20, 2017, 05:19:32 am »
Hi Scott,
Thanks for your answer! :)
I am afraid then that it's a simple converter... What I read in your comment is that to be able to use the converter to function as a DB9 joystick converter, it should be programmed? That is not the case and I doubt can be done for this one. See the attached picture.
Any suggestion of what plug-and-play converter (without programming involved) I should use?
greetz,
Martin
« Reply #3 on: October 20, 2017, 09:42:19 am »
What you have now is an RS-232 serial port to USB adapter.
What you need is called an "encoder".
Sounds like the type of encoder you're looking for changes joystick/button presses into gamepad outputs (gamepad-style encoder) rather than one that outputs keystrokes. (keyboard-style encoder)
Here's some general pinout info for MSX joysticks.
http://old.pinouts.ru/Inputs/JoystickMsx_pinout.shtml
Not sure exactly which version of "the arcade" joystick you have, but it appears that they are also Atari-compatible since most systems that used DB9 joystick port connectors used almost identical pinouts.
Raphnet has a DB9 to USB adapter with a built-in gamepad encoder >>> here <<< that should work for your setup.
Looking at the schematic from the related raphnet build-your-own-from-scratch project page:
- Up, down, left, and right are on pins 1-4 -- good for both MSX and Atari sticks
- Common is on pin 8 -- good for both MSX and Atari sticks
- Button 1 is on pin 6 -- good for both MSX and Atari sticks
- Button 2 (if your stick has one) might be on pin 7 which is labeled "select" on the raphnet adapter.
-- The project page mentions that the firmware has auto-detection, so you might want to ask them if your stick is already compatible.
-- Worst case scenario, you might have to make an adapter cable from a DB9 extension cable to connect joystick pin 7 to the correct adapter pin.
This page mentions that there may be a select switch button on the bottom of your stick that changes which button is conected to which pin.   :dunno
That's about as close to certain as I can get you without knowing the exact model and pinout of your stick.   ;D
qxb265
« Reply #4 on: October 20, 2017, 11:28:59 am »
Hi Scott,
Thanks so much for your elaborate reply!
I am gonna dive in to your leads about how to deal with it!
greetz from the Netherlands!
Martin
