Author Topic: Does Raspberry Pi output games at correct refresh rates to CRT?  (Read 7133 times)
crispux3
  • Last login:April 24, 2023, 04:42:12 pm
  • I want to build my own bartop arcade!
« on: October 12, 2017, 01:27:03 pm »
For instance, if I want to play MAME games that run at say, 54.7 Hz, 55Hz, or 58 Hz, will Pi play them correctly? Does Pi output SNES games at 60.08 Hz?
In other words, does the Pi output games at their exact refresh rates, or do you get frame skipping/tearing/etc. because it runs a game too fast or too slow? Also, if you have experience with retrotink, does it output refresh rates correctly?
Currently, I use groovymame and output to either my arcade monitor or PVM - would the Pi give me a similar/same experience? Thanks.
nitrogen_widget
  • Last login:November 19, 2025, 07:10:59 am
1500points
  • Last login:November 20, 2018, 01:44:12 pm
    • How to succeed at Robotron
Re: Does Raspberry Pi output games at correct refresh rates to CRT?
« Reply #2 on: October 20, 2017, 09:04:02 am »
Since you already have setups with Groovy and a PC, and you want that type of precision, you'll likely not be happy with Pi in general.
It doesn't have the emulation power that a PC does and due to its architecture you will have an inherent lag in everything...most people don't notice it depending on the speed of the game but it is still there.
Pi isn't for every gaming application, but it sure is good for lots of general gaming applications
SMB and Punchout on NES are two great examples where you can feel the limitations of Pi through the controls.
Titchgamer
« Reply #3 on: October 20, 2017, 09:08:39 am »
SMB runs fine on my Pi.
I did have to tweak some settings  to get it to run without noticeable lag though.
Grasshopper
  • Last login:March 04, 2025, 07:13:36 pm
« Reply #4 on: October 20, 2017, 07:44:57 pm »
The guy who maintains the AdvanceMAME project recently wrote a version customised for the Raspberry Pi that provides the facility to play games at their native resolution and refresh rate, just like the original PC version of AdvanceMAME did.
http://www.advancemame.it/
retrorepair
  • Last login:July 06, 2025, 06:47:43 pm
« Reply #5 on: December 12, 2017, 07:38:12 pm »
There is also RGB-Pi which apparently does what the OP is looking for, I'm skeptical though. It supposedly does output the appropriate resolution/refresh for each game but no one has mentioned if it will switch resolutions mid game for those that need it. If it does however it seems like a huge leap in the right direction for the Pi and makes it look a lot more interesting.
My arcade racing setup:
My Youtube Channel: http://www.youtube.com/user/RetroRepair
My Twitter: http://twitter.com/retrorepair
nitrogen_widget
« Reply #6 on: December 13, 2017, 08:34:29 pm »
not 100% sure but it looks like that is just a gertVGA put into a scart rgb cable.
retrorepair
« Reply #7 on: December 14, 2017, 06:47:35 am »
Well RGB-Pi is the project name, the SCART cable is pretty much a gertVGA but the OS is a modified version of recalbox. You can use it with a gertVGA instead of his cable if you prefer.
I've been testing it with a Pi 3 and gertVGA and it seems to work really, really well.
keilmillerjr
  • Web Developer.
« Reply #8 on: December 17, 2017, 11:13:45 pm »
Would the rgb-pi is work over composite you think?
retrorepair
« Reply #9 on: December 18, 2017, 10:24:40 am »
No because it exploits the Pi's DPI port for the resolutions. The composite port works differently. The adapters are only about 6 quid on amazon, but if you need composite for your display check out the retrotink:
http://www.retrotink.com
nitrogen_widget
« Reply #10 on: December 18, 2017, 02:50:46 pm »
Or you can grab an extron rgb unit off ebay cheap to do essentially the same thing.
may need an rgbscart to component convertor (also cheap)
i've read about it online but havn't done it yet though.
