Author Topic: LEDBlinky Animation Editor unexpected patterns!  (Read 2974 times)
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« on: September 19, 2017, 10:52:26 pm »
Hey All,
So I recently added a new feature to the LEDBlinky Animation Editor which displays an overview of the animations in a grid view (all controls across all frames). When I started viewing existing animations I was surprised to see some really interesting patterns. He are some examples...
Robots will kill you.
Arcade Addiction
headkaze
  • 0x2b|~0x2b?
Re: LEDBlinky Animation Editor unexpected patterns!
« Reply #1 on: October 12, 2017, 01:16:26 pm »
I created the default animations in Photoshop and wrote software to convert the png's into lwax format  ;D
arzoo
    • LEDBlinky
« Reply #2 on: October 12, 2017, 02:37:14 pm »
You're good, but are you that good lol!
Arcade Addiction
headkaze
  • 0x2b|~0x2b?
« Reply #3 on: October 12, 2017, 05:39:54 pm »
I found it interesting how you converted the lwax's back into pixels not realizing the default ones were created using pixels in the first place  ;D
It makes sense to make the default ones in Photoshop though as they're not tied to any one button layout so that's why I made them that way. I should really make some colored ones at some point.
It might be cool to add png importing to your Animation Editor. Another feature would be to allow the user to select groups of LED's then apply different waveforms (like sine, triangle, square, and sawtooth) to lerp the colors in some some way. I also remember sending you some code for a classic plasma effect which looks great too. Not sure if you ever implemented the effect into LEDBlinky?
ZoOl007
  • Last login:August 02, 2020, 12:03:38 pm
    • RGBcommander
« Reply #4 on: October 13, 2017, 02:30:44 am »
I'm interested in the plasma effect. So, if you feel like it you can always mail me that code.
PS: you don't happen to know how I can listen to all audio streams at once using alsa?
I want to make RGBcommander respond to audio. I had an equalizer and from that I could generate 00-FF's but  I only managed to listen to my own audio stream, not system wide.
Cheers
arzoo
    • LEDBlinky
« Reply #5 on: October 14, 2017, 03:55:05 pm »
Colored animations would depend on the wiring. I'm guessing most common is to wire ports in sequence as R,G,B,R,G,B... etc, but you never know.
Arcade Addiction
