Author Topic: Raspberry Pi Bartop Project  (Read 34487 times)
proplayer77
  • Last login:November 09, 2019, 03:23:58 pm
Re: Raspberry Pi Bartop Project - some questions
« Reply #40 on: October 06, 2017, 04:57:59 am »
SNES should be easy and the complete sets you'll find at the various sites online work fine.
N64 is just a bugger all the way around, real PITA.  I ended up getting Mario 64, Mario Kart and a racing game going but it was a LOT of effort and research.  Then the image got jacked, so I'm not sure I could easily retrace those steps.
Might be easier to just buy a cheap N64 console.  Thankfully they are still very reasonably priced.  shhhhh
Its ok if N64 wont work, have so much other roms so no prob :).  Also i was thinking that can i little tiny Rasp really work with N64 as they start to need more from the accelerators.
Snes i have to get working as best games ive played with Dolphin sofar are SNES. Of course Megadrive is cool too thats allready working.
About controls: at this point testing with a keyboard and a Wingman controller i have to give the controls every time i start the Rasp? Why is this. How can i save the configuration easiest.
Buttons and joysticks have arrived to Finland, so next week im sure i get them and start working with the real controls and shout for help :)!.
Titchgamer
« Reply #41 on: October 06, 2017, 05:26:24 am »
The controls should save automatically once you set them in ES.
Unless you mean changing the controls for individual systems?
If so thats a simple task that can become a real PITA!
You have to change them in retroarch then save core remaps etc.
proplayer77
« Reply #42 on: October 07, 2017, 04:07:43 am »
Snes came visible yesterday, so thats ok. Made the controlboard mounting. Im gonna try to not to make visible screws to the sides and front so thats a bit tricky part but well see. Im thinking when i attached the mounting first on the board that i can attach from inside (from backdoor) with screws to the sides.
« Last Edit: October 10, 2017, 06:13:54 am by proplayer77 »
Titchgamer
« Reply #43 on: October 07, 2017, 04:57:50 am »
Any screws on the outside just countersink them and fill/paint over.
proplayer77
« Reply #44 on: October 07, 2017, 07:20:09 am »
True, but for the control panel they need to be accessable  🙂
1500points
  • Last login:November 20, 2018, 01:44:12 pm
    • How to succeed at Robotron
« Reply #45 on: October 07, 2017, 09:53:50 am »
if you use strips of wood behind the panel you can counter-sink holes in the batting and screw into the underside of the control panel with no visible screws.
On my projects I use 1x2 strips as the sub-frame for screwing from the inside to the cabinet panels.  pre-drill and counter sink holes in the "batting" so it's easy to assemble from the inside.
When it comes to trackball mounting, you'd use round head carriage bolts which are going to be visible from the panel....the same as original arcade cabinets.
proplayer77
« Reply #46 on: October 08, 2017, 08:14:14 am »
Interesting. Do you have a picture of this mounting style?
I made the button holes today. Learned again that if you make them both ways be aware to not press to end. I made first hole like this and it was a mistake. 15/16 holes worked out fine with only pressing/drilling from visible side. Have to fix it. Going to use carbon vinyl so the surface still has to be straight for it to attach.
proplayer77
« Reply #47 on: October 08, 2017, 08:40:05 am »
I ordered these for powerdowning Pi and amp from alixpress. Im wondering as the powerdown circuit cost only 1 dollar for lot of 5 boards (including deluvery costs)can it really work 🙂. Amp costs 2,30€
I also bought the power chord you mentioned from local store for 14€. Ill put the Pi to Master and others to slave.
proplayer77
« Reply #48 on: October 08, 2017, 01:48:36 pm »
I have a question about t moulding. Whats the best way to do it? What kind of methods you use? I was thinking about leaving this first project without it but well see.
Also if you have good alternative methods (if not making t moulding) i have ears open for suggestions.
« Last Edit: October 08, 2017, 01:50:09 pm by proplayer77 »
Titchgamer
« Reply #49 on: October 08, 2017, 05:10:20 pm »
Best to cut T moulding slots before building or painting ;)
However you can cut the spine off the back and use 3M UHB tape to stick it to the edges.
I did it with good success on 2 of the edges of my bartop that were not routed for T moulding.
proplayer77
« Reply #50 on: October 09, 2017, 05:31:47 am »
Did you also use screws to hold it, or dows the 3M trick needed?
I have chrome moulding (used in cars, 16mm wide) without the spine with tape. Im just wondering will it hold without small screws on few places along the sides.
Titchgamer
« Reply #51 on: October 09, 2017, 06:10:58 am »
Mine held with just the tape, That stuff is expensive but super strong! Once it sticks you aint getting it off!!
Which is the downside really as if you ever need to get it off you will probably take chunks out of the wood!
proplayer77
« Reply #52 on: October 10, 2017, 03:09:26 am »
Applied carbon vinyl to control board yesterday night. My first experience with vinyling wood ever, so im quite satisfied with the result sofar.
« Last Edit: October 10, 2017, 06:13:03 am by proplayer77 »
ivwshane
    • My first mame cab! (WIP)
« Reply #53 on: October 10, 2017, 11:46:28 pm »
I don't know if you covered it but where did you get the vinyl from?
proplayer77
« Reply #54 on: October 11, 2017, 07:49:26 am »
Hi, i made it myself, first time ever with this material.
I ordered the carbon vinyl from alixpress, a set of 2m , 50cm wide.
More pics:
proplayer77
« Reply #55 on: October 12, 2017, 08:20:09 am »
Any idea why i have to add controls every time , retropie doesnt save them. Also ingame start doesnt work in many games, same 2 player. Cant find good tech help for this.
Titchgamer
« Reply #56 on: October 12, 2017, 09:01:44 am »
Can you be a bit more specific regarding your control problem?
Are you setting them up in ES? Is it just a certain system? Etc
proplayer77
« Reply #57 on: October 12, 2017, 10:16:49 am »
Yes, emulationstation. 1 add them they work. In game they dont work (tried with mame,snes,megadrive). When boot have to add them again in ES.
Titchgamer
« Reply #58 on: October 12, 2017, 11:38:56 am »
Thats odd.
I would guess you have got a problem with one or more of your cfg’s.
Once you set the controls up in ES they should save automatically once finished.
As for the individual systems you can reconfigure each individually through the retroarch menu once you have loaded a game from that system.
But you need to work out why ES is not saving controls first...
proplayer77
« Reply #59 on: October 12, 2017, 12:50:05 pm »
You mean configs ?
Titchgamer
« Reply #60 on: October 12, 2017, 02:14:28 pm »
proplayer77
« Reply #61 on: October 13, 2017, 05:18:55 am »
Do you know a good site to get instructions for these setups.
barrymossel
  • Last login:October 29, 2021, 11:25:52 am
  • Spectrum
« Reply #62 on: October 13, 2017, 05:30:10 am »
I don't know if you did a lot of tweaking with your setup, but you might try a fresh install. Never heard of EmulationStation not saving the controls (and I experimented a lot with it). And it's not a lot of work to re-install RetroPie (unlike...).
Titchgamer
« Reply #63 on: October 13, 2017, 07:04:18 am »
Not really, I found support for them to be lacking to say the least.
In my experience sometimes Retropie does something odd and you will spend hours looking for it and never find it.
So now I just start afresh with it and found that usually works out quicker as Barry mentioned.
I recently had a similar issue with my Mega Drive Pi.
Spent all day wondering why my retroarch configs kept changing, messing with stuff etc etc.
In the end the next day I spent about 2 hours wiped it and started again for it to all work perfect even though I hadn't really done anything different.
My best advice to you though is this: Use backups! Get the system to a "good state" then back up the SD images and continue on and back up after every stage. That way if something goes wrong you dont have much left to redo.
And at the end you have a back up incase your card gets corrupted etc.
proplayer77
« Reply #64 on: October 13, 2017, 07:34:59 am »
Thx, ive been busy last few days so this weekend ill try to get project further. I got the cases for speakers and have to decide what to do with the sides. Also leds are still on their way, amp too.
Ill try with fresh image. Should i update the Rasbian from console, thats one thing i havent done???? I dont know if it has anything to do with the Retropie mode.
What software you use to make the image from sdcard?
« Last Edit: October 13, 2017, 07:41:15 am by proplayer77 »
Titchgamer
« Reply #65 on: October 13, 2017, 07:42:59 am »
I use win32disk imager.
The best thing to do is get the latest prebuilt image from the retropie site and just add your content from there.
proplayer77
« Reply #66 on: October 14, 2017, 11:55:52 am »
Same i use thx. Now it remembers them on retropie but turns other control around after boot. Up is down and down is up, left is right...etc. Weird! Any ideas? Also on emus like mame - how to setup them for them separately?
Added ledstrips today.
Titchgamer
« Reply #67 on: October 14, 2017, 04:37:44 pm »
You can reconfigure the ES controller settings by pressing the start button on the home screen and re configuring the controller.
As for individual emus, load a game from the emu you want to re conf and press select and x button (i think it is) to enter retroarch menu.
You can then reconfigure as you please but you will need to make sure to have the save on exit function on otherwise they will revert back on exit.
Theres some good videos on youtube telling you the full procedure.
proplayer77
« Reply #68 on: October 15, 2017, 01:21:23 am »
Ive done that but after a while it reverses one of the control to wrong way.
Ill check retroarch.
proplayer77
« Reply #69 on: October 15, 2017, 06:32:07 am »
Im thinking about next project allready to future. Is one of these milling pieces ok for t moulding? Which one?
1500points
« Reply #70 on: October 15, 2017, 08:35:28 am »
just get it directly from t-molding.com.  they make it reasonably priced and have the exact item needed.
proplayer77
« Reply #71 on: October 15, 2017, 10:30:39 am »
Ok, ill check it out.
About the Retropie. I turned one joystick around and now it seems to work with both controllers all the time on emustation. I can also play snes and megadrive and atari games ok, BUT mame has issues. I cant even start a mame game once game is loaded. I tried x + select to get to retroarch of mame4all but cant find anything about controllers, only display etc???
proplayer77
« Reply #72 on: October 15, 2017, 10:57:54 am »
Both fans are running now when hitting power for the cabinet. I used a 12V DC, 500mA powersupply, it gives power to 12x12cm cabinet fan and also to raspberry pi:s 4x4cm fan which i attached together for powering.
I used a 10 year old Car Navigator power supply, perfect.
« Last Edit: October 16, 2017, 05:27:49 am by proplayer77 »
1500points
« Reply #73 on: October 15, 2017, 11:20:58 am »
For mame, hit tab in each game and map the controls like you would mame on pc.   For exiting game go into the ui settings in tab and set ui cancel to start and select together
proplayer77
« Reply #74 on: October 16, 2017, 05:28:29 am »
Ill try this. Yesterday the keyboard didnt respond on mame to anything.... :/
proplayer77
« Reply #75 on: October 17, 2017, 02:26:28 pm »
Ok, my usb hub seemed to be broken, now it got tab working when connected kb directly to rasp.
barrymossel
  • Spectrum
« Reply #76 on: October 18, 2017, 04:31:07 am »
I can recommend this hub for a RPi: https://thepihut.com/products/7-port-usb-hub-for-the-raspberry-pi
proplayer77
« Reply #77 on: October 18, 2017, 02:53:04 pm »
Thanks, i have one with own powersupply ill try but good to know alternatives .
proplayer77
« Reply #78 on: October 24, 2017, 06:36:42 am »
Project update:
im still waiting for
-new sticker for marque
-amplifier board
-electric switch
After that its all about decoration, if i dont leave it like this :)
proplayer77
« Reply #79 on: October 27, 2017, 11:53:39 am »
Some update on my bartop project.
-amplifier is still on its way, raspberrys own "amp" is terrible, almost no sound but im sure next week it will arrive
-electric switch the same :)
Marquee sticker came on tuesday and today i bought some u-rubber to get the plexi-edges done and secured properly.
Pics:
« Last Edit: October 27, 2017, 11:55:36 am by proplayer77 »
