Author Topic: 19" Nintendo Monitor (Mitsubishi)  (Read 6245 times)
zinger
  • Last login:February 25, 2019, 05:09:31 pm
  • There's a Donkey Kong Kill Screen coming up!
« on: September 02, 2017, 11:59:36 pm »
Hi guys,
I'm a newb to arcade monitors and I'm looking to buy a 19" Nintendo Monitor (Mitsubishi) for $80. This will be for my Donkey Kong. All I know is that its possibly been in a double monitor cabinet such as Punch Out and that it still works. It has some slight burn-in but likely not noticeable behind the DK bezel.
What concerns should I have? Will this work? I'm planning to pick this up on Monday.
Here are some pics:
grantspain
Re: 19" Nintendo Monitor (Mitsubishi)
« Reply #1 on: September 03, 2017, 04:09:22 pm »
do you know the actual model number of the monitor?
zinger
« Reply #2 on: September 03, 2017, 08:18:37 pm »
Here's more pics of tube and chassis.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: September 03, 2017, 09:53:31 pm »
Officially, only two 19" monitor makers were approved/supplied by Nintendo: Sanyo and Sharp.
behrmr
  • Last login:April 23, 2021, 09:17:13 am
« Reply #4 on: September 03, 2017, 10:23:46 pm »
The fact that you are seeing Ms. Pacman on there indicates that this monitor will NOT work with DK without a video inverter.
zinger
« Reply #5 on: September 03, 2017, 10:51:59 pm »
Thanks for the replies! What about hooking this monitor up to a PC? I'm assuming this would be easier since you don't need the inverter?
grantspain
« Reply #6 on: September 04, 2017, 05:36:30 am »
are you building your own cab or is it an original donkey kong cab?
if you are building a cab you can use that monitor and then just use a 60 in 1 game board and only have the donkey kong games enabled
if its an original cab complete then you could use that monitor and buy an inverter/sound board
I am not sure if that monitor requires an iso transformer, I am sure the seller can give you that info as he has it working.
zinger
« Reply #7 on: September 04, 2017, 12:04:04 pm »
This is for a DK cabinet that I'm building.
http://forum.arcadecontrols.com/index.php/topic,150085.0.html
The build originally started out as a MAME build but now I'm going for a DK replica with a DK board set, etc.
I need to buy my own iso transformer to go from 120V to 100V.
behrmr
« Reply #8 on: September 04, 2017, 01:58:06 pm »
Do yourself a favor and wire the cabinet JAMMA and buy a regular arcade std res monitor like the one you asked about. Get a normal ISO. Then buy Mikes arcade Nintendo JAMMA adapter. It has a built in sound AMP and video inverter.  I fixed up a cabaret and did this.   It's a lot easier than trying to source all the Nintendo harness parts and power brick.
zinger
« Reply #9 on: September 05, 2017, 01:43:51 am »
I lucked out on Craigslist today and found Sanyo monitors, DK board, power supplies w/ transformers, etc.
There are no cables for monitors except for the plug. I need to find out how to hook the monitor up to the DK board. Plan is to find the one that works best and then sell the other two. Apparently, they all work.
behrmr
« Reply #10 on: September 05, 2017, 10:47:15 am »
The harness pieces can be hard to find.  You can make your own edge connector harness following the DK pinout.  But you will need the "rainbow connector" that bridges power from the main PCB to the video PCB.
Mike's Arcade sells a lot of Nintendo stuff.  Here's the monitor cable
https://www.mikesarcade.com/cgi-bin/store.pl?sku=MONCBLNIN
zinger
« Reply #11 on: September 07, 2017, 12:52:17 am »
Thanks! I was able to order all of the wiring harnesses from MikesArcade. Also, I don't think I need the rainbow connector since I'm powering the CPU and video boards separately from power supply instead of chaining the power to the video from CPU board.
I read that the Sanyo monitor needs to be grounded to be discharged. Does the monitor need to be always grounded? I guess I could use the ground coming into the cabinet from the 120V power cord?
behrmr
« Reply #12 on: September 07, 2017, 10:32:52 am »
There are two different things to consider with "grounding" your monitor
1) When installed into your cabinet the frame of the monitor should be grounded to the cabinet's field ground (the middle prong from your outlet).  This is usually a shared ground to anything metal in your cabinet.
2) Discharging the monitor by grounding it is really only needed if you are going to disassemble it, wash it, or otherwise manhandle it.  If you are just putting it in the cabinet, there's really no need. Regardless, to discharge the monitor you need to ground the anode in the tube to the aquadag (black paint on back of tube) of the monitor.  You can take an alligator clip jumper wire and clip one end to the frame of the monitor.  Clip the other end to the shaft of a metal flat blade screwdriver.  Slide the blade of the screwdriver under the anode cup (the suction cup thingy on the tube with the red wire coming out of it).  Wait a couple of seconds and you're done.  You may or may not here a "snap".  This is a temporary deal.  E.g. you don't leave this grounded.  If you do this wrong and then handle the tube you may get zapped.  It won't kill you it will just more or less piss you off.
Good luck.
