Author Topic: Image blur using CRT Emudriver 2.0 and some modern cards...  (Read 2778 times)
silmalik
  • Last login:April 16, 2022, 09:08:13 am
    • Mednafen emu4crt mod
« on: August 23, 2017, 06:53:37 pm »
Hello,
I've recently decided to upgrade my system video card from HD4550 to R5 230 (Crimson 16.2.1 non-GCN / Windows 7 x64).
CRT Emu driver/VMMaker installation process with all resolutions is ok but it seems that a filter is now applied on all interlaced resolution.
The image is blurred, with a great loss of precision.
The card is flashed with ATOM and "native" 640x480 15kHz mode with default VGA driver is ok, but once CRT Emu/AMD driver starts, the image turns blurred.
No such behaviour with the old 4550.
I tried after a complete system re-installation and on another Windows 10 system with a HD7850 (GCN drivers) and I had... the same blurred result  :cry:
Is this an expected behaviour? Is there a known possibility to get rid of this horrible effect ?  ???
Thanks for reading and for any response.
Paradroid
  • Last login:July 12, 2025, 08:11:33 pm
    • SCART Hunter
Re: Image blur using CRT Emudriver 2.0 and some modern cards...
« Reply #1 on: August 23, 2017, 08:48:24 pm »
Yep. Expected behaviour: modern cards apply an anti-flicker filter by default.
Some people see it as a positive but, personally, I despise it. I went back to trusty ol' XFX 4350s.
Sent from my SM-A300Y using Tapatalk
My MAME/SCART/CRT blog: SCART Hunter
silmalik
« Reply #2 on: August 24, 2017, 05:24:25 am »
Thank for your answer.
HD4xxx have issues with interlaced mode too, related to synchronization.
So, is there a perfect solution?
Do we know if the HD4xxx interlaced sync issue is related to hardware or drivers?
If HD4xxxx sync problem has hardware source, a potential solution could HD5450 with CRT Emudrivers based on Catalyst 12.1.
Paradroid
    • SCART Hunter
silmalik
« Reply #4 on: August 24, 2017, 09:11:38 am »
Thank you, I've already fixed polarity as described in the topic.
My issue with HD4550 is a bit different.
For example, running mednafen in 480i is mostly ok, but I encounter slowdowns at some times during seconds. Only in fullscreen, never in windowed mode.
R5 230 is 100% ok on this aspect.
