Author Topic: Can't use Mame to create Mamelist.xml -- anyone have a copy?  (Read 3488 times)
SpatzST
  • Last login:April 18, 2021, 05:29:46 pm
« on: August 12, 2017, 08:30:52 pm »
I just updated all my roms to .188 and I am trying to create a new mamelist.xml but mame fails to create it every time.  Does anyone have a copy or knows why it isn't working? I tried using Don's tools to do it and it just says something about there being a syntax error maybe so it didn't work. I end up with a 0 byte file after 30m of processing.
DoTheDonkeyKonga
  • Last login:October 24, 2017, 09:05:25 am
  • Butterfly
Re: Can't use Mame to create Mamelist.xml -- anyone have a copy?
« Reply #1 on: August 14, 2017, 11:23:00 am »
How are you trying to create the mamelist.xml file? Also where is your mame executable located and where are you trying to save the mamelist.xml file to?
I'm in work right now but I will try to generate mamelist.xml from .188 later on and see if it works for me.
"Never take yes for an answer. The nature of things is always no." -- Aldous Huxley, Island
Robbbert
  • Last login:August 01, 2025, 01:43:54 am
« Reply #2 on: August 16, 2017, 12:25:48 am »
- nvm -
« Last Edit: August 16, 2017, 12:30:48 am by Robbbert »
chillinwater
  • Last login:February 01, 2022, 12:13:55 am
« Reply #3 on: August 16, 2017, 12:28:10 am »
Literally, less than 30 secs before I saw this post, I was reading this post...
http://www.mameworld.info/ubbthreads/showthreaded.php?Number=368531
Hope it helps. I have not tried it yet.
ark_ader
  • I glow in the dark.
