Author Topic: [FIXED[ San Francisco Rush 2049 SE Graphic Glitches [FIXED]  (Read 6617 times)
05SRT4
  • Check out my Pow Pow
Hey guys,
I just noticed some graphic errors popping up on my Rush 2049 arcade.
I only see them at certain times, mainly in the actual races. The loading/attract mode does not have them, car select does not have them either.
I dont think its an issue with the monitor because its fairy new, maybe 10 hours of on time. I checked the video cables, took what  I think is the graphics card (On far left of board) and cleaned the contacts. I didn't want to start taking chips out  because I dont really what what I am doing or looking for.
Do you think this might just be the graphics card going bad?
As you can see below, the sky has horizontal lines, and the Map/car also have the same lines. these only show up when racing. Other times the lines will show up on the roads but they are vertical.
« Last Edit: October 21, 2017, 02:55:36 pm by 05SRT4 »
  • Last login:Today at 12:37:09 pm
Re: San Fransico Rush 2049 SE Graphic Glitches - Need Help
« Reply #1 on: July 20, 2017, 08:03:30 pm »
It could be the graphics card or the power supply.  Those are definitely render errors so either the card is bad or it isn't getting the proper voltage.
05SRT4
« Reply #2 on: July 20, 2017, 08:08:25 pm »
Thanks Howard, the power supply is available online so I will check that out. I also found some troubleshooting steps in the manual that I will try when I get home.
Question about the Video card, the manual says its a Betson Imperial Board “Voodoo3 – 3500”
I am guessing these cant be swapped out with another Voodoo3 3500 APG board? I am guesing their board has special firmware or something?
05SRT4
« Reply #3 on: October 11, 2017, 11:31:03 am »
Switched out the HDD for a Flash Card kit, replaced both rom's also since it came with the kit, checked voltages and used an external monitor. Still happening. I gotta find a new graphics card but its seems damn near impossible.
05SRT4
« Reply #4 on: October 21, 2017, 02:54:56 pm »
Well I found a 3DFX Interactive V32316 Voodoo 3 PCI card on ebay for 50$ Bucks. Ended up working and fixed the glitches.
shaolindrunkard
  • Last login:June 11, 2025, 09:02:25 pm
Re: [FIXED[ San Francisco Rush 2049 SE Graphic Glitches [FIXED]
« Reply #5 on: October 21, 2017, 08:19:15 pm »
Nice man, if I were you I'd keep an eye out on ebay for those and snatch up a few more whenever they come up just in case another one goes bad for you and you have trouble finding one again...
05SRT4
« Reply #6 on: October 21, 2017, 08:34:23 pm »
A very good idea.
