Author Topic: scanline generator  (Read 2955 times)
Moksi
  • Last login:March 17, 2025, 08:13:58 am
scanline generator
« on: July 16, 2017, 07:40:18 am »
Ordered a scanline generator for my setup, only my graphics card doesnt have vga port.
So tried an dvi to vga converter and then connected the vga cables with the scanline generator to the monitor.
only the signal gets disturbed with a 2 sec interval
I have an option getting another graphics card in the desktop with an vga output
lets say can i adjust mame to use that second card with vga , and use the first as standard graphics card
any advice is welcome
  • Last login:Yesterday at 09:37:10 am
Re: scanline generator
« Reply #1 on: July 16, 2017, 12:38:02 pm »
What model graphics card do you have?
Yours might be able to output VGA through a simple DVI to VGA adapter, but first you'd have to set it in the graphics card software so it would output the correct type of signal to the appropriate pins.
Moksi
« Reply #2 on: July 16, 2017, 01:41:51 pm »
nvidia Geforce GTX 960 is what i have .
Hmm if didnt know about that if you know where i need to set the option for that i will try to it out again
« Reply #3 on: July 17, 2017, 11:34:52 am »
I haven't messed around with this on newer cards.
A quick google search says it will work with a cheap passive cable or adapter.
It must be connected on the DVI-I port and should be automatically detected without having to set anything in software.
If it's the only monitor that is connected, you may need to reset the computer so it has a chance to detect it on startup.
(may take a couple tries)
http://nvidia.custhelp.com/app/answers/detail/a_id/221/~/difference-between-dvi-i-and-dvi-d
Moksi
« Reply #4 on: July 19, 2017, 04:04:52 pm »
just tried it again to setit up but the thing is when i connect it with the dvi to vga converter with the scanline generator the display works
but as soon as i switch the scanlines on i get that annoying disturbing in the screen.
The owner of the product told me i should use an upscaler
but dont know for sure if it doesnt give me that disturbing signal
« Reply #5 on: July 19, 2017, 04:19:24 pm »
Dunno what to tell you.  The only scanline generator I have experience with is the mini SLG http://forum.arcadecontrols.com/index.php/topic,129344.0.html
It only works with 640x480 & 1024x768 resolutions.  The versions I had were older and didn't have a switch.
