Author Topic: Are the accent bulbs on the Row AMI CD100G #73 or #74?  (Read 4485 times)
fredw1970
  • Last login:January 14, 2025, 06:24:32 pm
  • "But I don't wanna be a pirate!"
« on: June 29, 2017, 10:34:58 pm »
I need to replace a number of burnt out bulbs on my CD100G, but I don't remember if they are #73 or #74 bulbs?
I am thinking about swapping them out for LED's from superbrightleds.com but they are #74's and don't want to buy a bunch (I think I need 62) only to have them not fit.
Also, in the case that any of the plastic bases stop working, do you know where I can get a new locking base?
Ken Layton
  • Guru
  • Technician
Re: Are the accent bulbs on the Row AMI CD100G #73 or #74?
« Reply #1 on: June 30, 2017, 12:34:01 am »
Rowe uses #73 miniature lamps in the CD-100 series jukeboxes.
fredw1970
« Reply #2 on: June 30, 2017, 09:42:40 am »
Thanks Ken... If I am swapping them for LED equivalents that say they are comparable to either #73 or #74 that should work right?  The only thing that appears different between the bulbs is the filament diameter and run time before failing.
https://www.superbrightleds.com/moreinfo/miniature-wedge-base/74-led-bulb-1-led-miniature-wedge-retrofit-car/226/#/attributes/10826
Ken Layton
  • Guru
  • Technician
« Reply #3 on: June 30, 2017, 11:25:22 am »
The differences between 73 and 74 are minor, mainly in hours of life.
fredw1970
« Reply #4 on: June 30, 2017, 02:59:34 pm »
Thanks... I was considering putting in LED's but since most are directional they might yield the best visuals, unless I buy 360' LEDS, but at nearly $2.50 each and (I believe) 62 bulbs not sure I want to spend that kind of $$$.  I found some #73/#74 Halogens that might work well, brighter than the OEM bulbs.  Hoping they won't get too hot and melt the plastic..
lilshawn
  • Last login:February 20, 2026, 07:25:33 pm
« Reply #5 on: June 30, 2017, 05:16:04 pm »
a #73 bulb is 1.12W, the #74 is 1.4W slightly different light output but other than that, physically identical.
since you are going LED it doesn't matter a spit.
