Author Topic: Finished Street Fighter 2 Champion Edition machine  (Read 6489 times)
Ward-iz
  • Last login:March 28, 2018, 05:26:55 am
« on: June 11, 2017, 08:59:18 am »
Here's the finished Street Fighter 2 machine I've been working on the past couple of months. I got the cabinet with no monitor or artwork , still had the power supply, speakers and the marquee light worked.
Installed a sony trinitron 29 inch screen that I decased and was able to wire the tv's sound into the original arcade speakers. Also has a sub in the cab .
Has a pc inside running hyperspin , made some custom intro's  and added music to them.
Has an IPAC2 and did a xbox usb controller hack to make the arcade controls work good with games on steam.
Hooked it up to a projector for games nights.
Here's a link to the finished product.
« Last Edit: July 16, 2017, 12:56:10 pm by Ward-iz »
matsadona
Re: Finished Street Fighter 2 Champion Edition machine
« Reply #1 on: June 11, 2017, 09:46:55 am »
Another game is always a good game :) Any details about how you hooked up the TV and the projector?
Ward-iz
« Reply #2 on: June 11, 2017, 10:27:49 am »
I used a hdmi to vga adapter from the pc , then that plugs into a vga to cga converter board which I have the tv hooked up to via s-video . For the projector I ran an extra vga cable to it . The vga to cga converter board has s-video , vga and composite video outputs that you can run simultaneously.
« Last Edit: June 11, 2017, 10:40:52 am by Ward-iz »
mourix
  • Last login:November 19, 2025, 01:04:17 pm
« Reply #3 on: June 12, 2017, 06:46:52 am »
Really love the transformation to fully original outside with brand new insides. :applaud:
Small thing though, why did you not use a graphics card with DVI output? That connector also contains VGA and would have saved you a step in the processing chain.
  • Last login:November 19, 2025, 04:34:38 am
« Reply #4 on: June 12, 2017, 06:58:47 am »
That seems to be a lot of unnecessary video conversion. I don't know how much lag that will create.
Ward-iz
« Reply #5 on: June 13, 2017, 03:55:18 am »
I haven't really noticed much lag , I'm able to play games like tekken 7 , mortal kombat 9, 10 , dead or alive 5 , street fighter 4,5 and all older mame games pretty smoothly . Hasn't been an issue that I've noticed affecting the gameplay atm.
n3wt0n
« Reply #6 on: June 13, 2017, 07:43:29 am »
nice job! any pics of the decased TV? I like to see how people tackle that.
matsadona
« Reply #7 on: June 13, 2017, 12:38:13 pm »
Thanks for the reply with details. Must admit that I'm a bit surprised that you still get that good picture with that process. I was sure you had something with ArcadeVGA or GroovyMame... Interesting.
Ward-iz
« Reply #8 on: June 15, 2017, 02:45:19 am »
Here's a photo of the decased Sony 29 inch tv . Wasn't very difficult to decase and mount . I have pretty much no experience in decasing tv's, so it was a learn as you go experience . Just had to make sure all the wires and plugs were connected after I had mounted it inside the cabinet . Also connected the arcade machines speakers to the speaker wire inside the tv . This allows the game volume to be adjust easily .
SGGG2
  • Last login:June 25, 2017, 06:25:47 pm
« Reply #9 on: June 25, 2017, 06:25:47 pm »
Awesome! What's the music accompanying "Taito Type X"?
Ward-iz
« Reply #10 on: July 02, 2017, 08:00:16 am »
The track is - Hajime , by an artist called Bestrack
Ward-iz
« Reply #11 on: July 16, 2017, 01:33:33 pm »
Here's a more in depth video of the work I did to the machine.
