Author Topic: hantarex polo/3 with tv monitor  (Read 2120 times)
shipley john
  • Last login:June 09, 2017, 03:20:38 pm
« on: June 02, 2017, 02:37:15 pm »
I have a flat table top hanaterex polo 3 circuit board but the monitor went. I have fitted a Panasonic 14inch TV monitor to it ,all fits but the rgb off the tube does not go onto the board. Think it's cn11 any ideas bit out of my depth. Or better to get a monitor tube. Thanks
grantspain
Re: hantarex polo/3 with tv monitor
« Reply #1 on: June 02, 2017, 05:51:20 pm »
when you say the monitor went do you mean the chassis developed a fault or did  the tube get broken?
the Panasonic monitor you fitted is it a pc monitor?
Are you in Yorkshire?
shipley john
« Reply #2 on: June 03, 2017, 01:56:25 am »
The monitor went, so fitted old Panasonic TV monitor in place, everything fits apart from the egg cable off the monitor.cheers
grantspain
« Reply #3 on: June 03, 2017, 03:48:50 am »
polo 3 are a 15khz monitor
if the Panasonic is a pc monitor it will be 31khz, depending on what game board is in the cab depends on if you need a resolution upscaler
need a bit more info from you, what game board is in the cabinet and what inputs are on the Panasonic monitor(i.e vga d-sub, scart )
