Author Topic: arcade monitor problem  (Read 3049 times)
Zed-eX
« on: March 31, 2002, 12:52:08 pm »
??? i have a problem machine the monitor seems to work for about 5 mins then slowly fades to black and will only restart after a 30 min wait there is constant power running to the monitor but i am at a loss as to what the problem is
Cfish
Re: arcade monitor problem
« Reply #1 on: May 31, 2002, 11:52:29 am »
It would be helpful if you provided more details - such as type of monitor, is it enclosed, age possibly...  but off hand, I would say you have either an overheating problem, or a power supply failure.  Check to make sure you have enough circulation around it - use a fan on it (not too close - magnets you know...) and see if it stays on for a while longer.  Try swapping the power supply out if you can do so safely - I don't know your level of experience on this stuff, but it's not for the novice tinkerer.  If niether of these work, and it's not under warranty, call around and see what it will cost you to have someone look at it - it may be cheaper to buy a new one - good luck!
