Author Topic: Megatouch force  (Read 6503 times)
spanks_4
  • Last login:September 28, 2018, 10:41:24 am
Megatouch force
« on: May 31, 2017, 10:07:30 am »
I got this from a friend and it works....Somewhat.
It will do the full boot up, but has random freezing. Sometimes it freezes as soon as it boots and other times it will let you play a game or five before freezing.
Is it the motherboard needing a cap kit or something else? The HD has been swapped out for an SSD drive running 2011 which has been put in another game and ran for hours without issues so HD is not the problem.
orizzle
  • Last login:September 21, 2020, 07:20:41 pm
Re: Megatouch force
« Reply #1 on: May 31, 2017, 10:15:33 am »
heat.  clean out and/or replace fans. specifically cpu fan
spanks_4
Re: Megatouch force
« Reply #2 on: May 31, 2017, 10:24:07 am »
will try that tonight thanks.
lilshawn
  • Moderator
  • Last login:January 26, 2026, 07:56:08 pm
Re: Megatouch force
« Reply #3 on: June 01, 2017, 02:18:47 pm »
the stock CPU coolers where absolute trash. the Thermal interface material (TIM) was one of 2 varieties... a double sided sheet of aluminum foil with graphite on it. or a yellow TIM with the consistency of hard soap.
neither one is any good...at all.
remove the cooler, remove the TIM from the heatsink and CPU with some isopropyl alcohol and replace it with good paste. temps will be 20 degrees cooler.
spanks_4
Re: Megatouch force
« Reply #4 on: June 01, 2017, 04:17:49 pm »
Where can I get a better fan? Is TIM the same as heatsink compound? That stuff I have a fresh tube of
ed12
Re: Megatouch force
« Reply #5 on: June 01, 2017, 04:35:23 pm »
buy real good thermal  paste
i use mg chem.
some what expensive  but it has never failed me before
ed
lilshawn
  • Moderator
Re: Megatouch force
« Reply #6 on: June 01, 2017, 05:15:47 pm »
if you got some good stuff like arctic silver or MG Chem silicone, great. if it's radioshack 6.99 special. not so much.
as long as the fan is not seized, it should be fine, they used a ball bearing fan in some of them so they get noisy, but still spin. if you peel the label off the back of the fan you can see if it's ball bearing or a sleeve bearing. sleeves seize up.
