Author Topic: High Score Competition #218: Peggle (joystick)  (Read 5402 times)
jasonbar
  • Dr. Inferno
    • The Infernolab
« on: May 23, 2017, 12:43:52 am »
(Trackball/spinner is clearly the way to go, but that would likely prevent some from competing.)
"Game in which you control a rotating circle of pegs which you try to get a falling, bouncing character to touch and eliminate." (Wow, eliminate? Gross...)
https://www.arcade-museum.com/game_detail.php?game_id=18626
Rom : peggle
2-way Joystick
Default settings
Scoring Time Initial: 60
Scoring Time Extra Racks: 20
Competition ends Sunday June 4, 2017, midnight Pacific Time.
PS--first quickie game score: 19,900
PPS--I remember this being more fun when I played it a while ago--hopefully I was right then & wrong tonight...
GrizzlyThunder
  • Last login:January 15, 2026, 09:02:03 pm
Re: High Score Competition #218: Peggle (joystick)
« Reply #1 on: May 23, 2017, 01:02:03 pm »
19800 so far
This game is challenging without a spinner. I was getting wicked frustrated with that dude and my coordination lol. Fun game though.
WeChat: GrizzlyThunder
yamatetsu
  • Last login:Yesterday at 04:42:12 pm
  • Just because.
« Reply #2 on: May 25, 2017, 12:35:14 pm »
49,600.
72,310.
« Last Edit: May 27, 2017, 10:38:50 am by yamatetsu »
yamatetsu
  • Just because.
« Reply #3 on: May 28, 2017, 02:12:01 pm »
Scores so far.
yamatetsu            72,310
jasonbar              19,900
GrizzlyThunder     19,800
Titchgamer
« Reply #4 on: May 28, 2017, 07:05:14 pm »
Gana try and get on this tomorrow time permitting.
GrizzlyThunder
« Reply #5 on: May 31, 2017, 07:21:39 pm »
I am still struggling with this game, any tips? Cursing at the thing has not been effective.
yamatetsu
  • Just because.
« Reply #6 on: June 01, 2017, 03:02:35 am »
- Learn how to control PeggleMan. Instead of just letting him drop onto a peggle, whack him with the peggles, so that he goes flying. You can keep him up by alternately hitting him left / right,
  by hitting him from below or by smashing him into the screen boundaries.
- As long as you have got time left, do not use the trampoline or the clock extra, as those might save your life later.
- As long as you have got time left, go for the ?, this might give you 5000 points if you are really lucky.
- Whacking PeggleMan with peggles that need more hits to be destroyed often destroys them with a single hit.
- You can use the springs between the vats to jump over the vats so that you land in the one that you want.
- Keep cursing.
yamatetsu
  • Just because.
« Reply #7 on: June 01, 2017, 03:47:37 am »
82,960. Heeding my own advice actually helps. Who would have thought that.
Greenman
  • Last login:January 03, 2025, 06:02:48 pm
  • Made in Australia
« Reply #8 on: June 02, 2017, 05:59:19 am »
I am rubbish at this.
My previous projects:
Greenman
  • Made in Australia
« Reply #9 on: June 02, 2017, 06:03:43 am »
17,500   :banghead:
yamatetsu
  • Just because.
« Reply #10 on: June 03, 2017, 03:32:43 pm »
Show off.
Sent from my SCH-I545 using Tapatalk
Showing off again. You get a 'perfect rack' for popping all pegs in one go without touching the vats, not even the trampoline.
Level 1 :
Level 2 :
JDFan
« Reply #11 on: June 04, 2017, 11:11:45 am »
Finally had some free time to play a bit - 90,680
Got lucky and got passed the 5th stage and then the 6th is pretty easy and 7th has dual characters to control. Tried a couple more games afterwards but couldn't get past the 5th wave again so could only get to 70K. The points add up quick once you get going. Still a little time so might keep trying to break 100K - but doubt I can make it to the 180K 1st place default score.
Definitely helps to learn how to control him at the carts - save the time extend and use the trampoline until you have to use the time extend if the trampoline hasn't reset and you can keep him in play for a good bit of time.
« Last Edit: June 04, 2017, 12:47:34 pm by JDFan »
yamatetsu
  • Just because.
« Reply #12 on: June 05, 2017, 12:23:02 pm »
The scoreboard.
Jason, it's your turn again. Yay!
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #13 on: June 05, 2017, 12:35:27 pm »
Will do. Hopefully tonight.
Thanks for maintaining the scoreboard.
-Jason
jasonbar
  • Dr. Inferno
    • The Infernolab
