Author Topic: WTB TV adjustment tools?  (Read 3553 times)
« on: May 22, 2017, 12:42:08 pm »
Hi guys,
I've bought a couple of crappy TV adjustments tools in my day and I'm finally looking for a proper set.  Anyone have any links?  I tried the Amazon route and came up with these...  I ordered both and they are not cutting it.
These are garbage:
https://www.amazon.com/Philmore-Anti-Static-Alignment-Trimmer-63-910/dp/B00K3VS7TM/ref=sr_1_2?ie=UTF8&qid=1495469779&sr=8-2&keywords=tv+adjustment+tool
Believer it or not, these ceramic ones were better, but I'm looking for specific ones just for TV's:
https://www.amazon.com/REAMTOP-Slotted-Ceramic-Alignment-Screwdriver/dp/B06XGF8Q8Q/ref=sr_1_2?ie=UTF8&qid=1495470886&sr=8-2&keywords=ceramic+alignment+tool
These look OK but I was curious what you guys prefer as a kit?
http://www.frys.com/product/7300604?site=sr:SEARCH:MAIN_RSLT_PG
Thanks in advance!
DeL
ed12
Re: WTB TV adjustment tools?
« Reply #1 on: May 22, 2017, 01:02:03 pm »
the last 1 frys is the perfered kit for most techs
because of the small meat tips
be warend from the start if u have a stuck coil
u will strip them real fast
if u need i will round up the best (which i went to after a few years)
but they are a tad pricey
ed
lilshawn
  • Last login:January 26, 2026, 07:56:08 pm
« Reply #2 on: May 28, 2017, 08:41:55 pm »
I start with a metal tool (powered off first of course)  to make sure it's loosened up, then use the plastic tools.
I just turn it 1/4 turn one direction, then 1/2 turn back... then 1/4 forward again (to end up where i started.) the adjustment slugs are often melted into the plastic a bit and need to be released.
The plastic tools work great after that, power it up and adjust away.
  • Last login:Yesterday at 07:02:00 pm
« Reply #3 on: May 28, 2017, 08:59:20 pm »
Now THAT'S a pro tip!!
Ken Layton
  • Guru
  • Technician
« Reply #4 on: May 29, 2017, 12:04:14 am »
GC Electronics makes the best ones and have the best sets of kits:
http://www.gcelectronics.com/order/SubCatPDF/alignment%20tools%20Kits%20380-387.pdf
GC Electronics tool # 8606-L is the only one I use on ALL makes/models of arcade monitors. One end has a hex tip that fits width coils and the other end is a straight slot tip for turning trimpots. Plus it's plenty long to get your hands away from the high voltage wire when adjusting the width coil on a K7000.
This place sells the tool for only $1.50:
https://www.onlinecomponents.com/gc-electronics-8606l.html?p=11424375
It's on ebay too:
http://www.ebay.com/itm/Inductor-Coils-Tuning-Tool-by-GC-MPN-8606L-/192172921498
« Last Edit: May 29, 2017, 12:09:43 am by Ken Layton »
« Reply #5 on: May 30, 2017, 09:01:52 pm »
Thanks guys!  Will give these a shot.
