Author Topic: Mini Pac not waking pc  (Read 2059 times)
netboy
  • Last login:December 19, 2022, 01:55:28 am
« on: May 18, 2017, 04:43:40 pm »
I have a mini pac that will not wake the pc but they actual keyboard or mouse will.  I have tried unplugging the keyboard/mouse(single usb dongle) disabled usb selective suspend sleep but neither of those work.  I am not sure what else to try.  Does anyone have any suggestions?
Titchgamer
Re: Mini Pac not waking pc
« Reply #1 on: May 18, 2017, 05:18:56 pm »
Turn off sleep mode ;)
DrLarryE
  • Last login:January 23, 2018, 10:03:26 pm
« Reply #2 on: May 18, 2017, 07:33:29 pm »
I had the same question but I am more interested in learning why a keystroke through an ipac won't wake a computer.  The ipac LED is on when the computer is in sleep mode so it is powered.  It connects to the computer via a USB port, just like the keyboard.  I don't think there is anything wrong, just different.  Anyone know what?
netboy
« Reply #3 on: May 18, 2017, 09:42:31 pm »
Figured it out sort of. I just made shift commands for both sleep and wake. As to why pushing the stick or buttons won't wake the pc I have no clue.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #4 on: May 21, 2017, 02:00:04 am »
The reason for a dedicated wake configurable key is for maximised response. When wake is activated its necessary to check that the PC is in fact in sleep mode before sending the wake which causes a USB bus reset. This check is only done when the wake-assigned key is activated.
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« Reply #5 on: May 24, 2017, 10:52:13 pm »
I just put a dedicated power button on the back of the cab hooked up to the power on the mobo.
