Author Topic: Getting Stable controller id's...can't get it to work with gm  (Read 3778 times)
retrogamer123
  • Last login:April 11, 2021, 04:06:23 am
Basically I was trying to follow the official docs on this
http://docs.mamedev.org/advanced/devicemap.html
I put the cfg file in the following foldre
ctrlr/xbox360.cfg
I set the ctrl path in groovy mame to ctrl
and in the core input options I set:
Code: [Select]
ctrl xbox360
Thats the working part. So fine so good. Starting groovymame with a game also uses my controller mappings.
But as soon as I add the following to my cfg file:
Code: [Select]
<mapdevice device=”XInput Player 1” controller=”JOYCODE_1” />
<mapdevice device=”XInput Player 2” controller=”JOYCODE_2” />
groovymame gives me an error that it can't load the controller cfg file
I'm using the d3d9x build of groovymame 0.183
Does anyone have any idea what I'm doing wrong ?? ???
Calamity
  • Moderator
  • Last login:Today at 10:56:16 pm
  • Quote me with care
Re: Getting Stable controller id's...can't get it to work with gm
« Reply #1 on: May 13, 2017, 07:28:16 am »
What happens with official MAME?
Steps to create a log:
ozfalcon
  • Last login:November 30, 2025, 12:40:52 am
  • ZSystem
« Reply #2 on: May 13, 2017, 11:51:18 am »
ctrlr/xbox360.cfg
Code: [Select]
ctrl xbox360
Code: [Select]
Did you copy and paste the example?
Code: [Select]
<?xml version="1.0"?>
<mameconfig version="10">
    <system name="default">
        <input>
<mapdevice device="XInput Player 1" controller="JOYCODE_1"/>
<mapdevice device="XInput Player 2" controller="JOYCODE_2"/>
        </input>
    </system>
</mameconfig>
Your double quotes are not correct (Docs have formatted double quotes, Mame requires standard double quotes).
« Last Edit: May 13, 2017, 12:01:49 pm by ozfalcon »
retrogamer123
« Reply #3 on: May 13, 2017, 12:33:56 pm »
@ozfalcon.
Thx so much. Yes, you were right.I had the wrong doublequotes.
Its working now, cause the verbose output of mame now shows the remapped controller messages :)
