Author Topic: Default HyperSpin issue  (Read 2653 times)
snaus
  • Last login:February 10, 2020, 09:19:45 pm
« on: May 07, 2017, 09:45:00 am »
Hi, I got my cabinet running but...  I set the frontend to HyperSpin location and use HyperSpin as  Default plugin and everything runs good.... then I get,
Error: "-10" is not a valid key name.    Line # 9300 Hotkey,%exitScriptKey%,CloseError
When I return to RocketLauncher UI the Frontend and Default Plugin have both changed  to RocketLauncher instead of HyperSpin.  Then I change them back and everything is fine again for a bit.  Anyone know how to fix this?
Thanks ,
Snaus
