Author Topic: Groovymame in New Net City  (Read 2660 times)
Kidpanda
  • Last login:July 18, 2021, 04:02:56 pm
« on: April 29, 2017, 09:10:50 pm »
Hello! So I've been running into issues when playing games that use the cave.cpp driver i.e. Donpachi, Dangun Feveron, Air Gallet, etc. Every once in awhile, not really in timed intervals, I will have the screen get dim and also shrink then fix itself back again. It only does it on the games that run at 57hz, Games like Raiden and such run fine but for some reason these games in particular are having issues.
My setup is
New Net City using a Toshiba PF Monitor with a d29c051 chassis
Groovymame 0.182
CrtEmu 2.0 with 12.6 drivers
Windows 7 x64
Pentium G4560 @ 3.5Ghz
AMD HD4350
Super Resolutions
I've added a link to a video of what it does with that particular driver, it happens pretty much when the video starts. Hopefully I have given enough info to maybe help me with this situation. Thanks for any help!
Calamity
  • Moderator
  • Last login:July 01, 2025, 01:29:14 pm
  • Quote me with care
Re: Groovymame in New Net City
« Reply #1 on: April 30, 2017, 04:04:57 pm »
That's odd, I'd say the monitor is failing if you hadn't mentioned it only happens with 57 Hz games. If that is true.... you could bypass the offending frequency by tweaking your crt_range configuration.
Steps to create a log:
Kidpanda
« Reply #2 on: May 10, 2017, 09:05:46 am »
Revisiting this, so I moved my rombox to my Egret 3 which has a Rodotron chassis in it and the games work perfectly fine. Talked to a bud of mine and he told me to try and wire the video input from the Jamma harness directly to the chassis via the AMP plug bypassing the VGA on the NNC. Will do that soon and report back with my findings.
