Author Topic: Bezel for rotating monitor -any ideas out there?  (Read 1744 times)
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« on: June 04, 2002, 03:22:06 am »
Hi!
Basically I know who to make a bezel -but since I'm going to have this rotating monitor on my cab, I wonder how I shall get this close enough to the glass so that you can't lurk beside the monitor?
If the monitor would stand in one position, the Lexan could probable "lean" on the monitor (e.g. with black tape between), but how to make it with a rotating one?
Any ideas? I still wanna have the possibility to add some artwork on the sides of the bezel to get a more authentic look.
enemyace
  • Last login:February 23, 2003, 01:23:43 pm
  • You repo men, you're all out to @!$#in' lunch!
Re: Bezel for rotating monitor -any ideas out ther
« Reply #1 on: June 04, 2002, 07:47:01 am »
Why not make a big black circle that is that same diameter as the diagonal dimensions of the monitor? It would have a rectangular hole in the center for the screen, and would rotate with the monitor, behind a sheet of fixed plexiglass. The bezel artwork could be affixed to the back of the plexi so that it doesn't rotate.
telengard_cant_log_in
Re:Bezel for rotating monitor -any ideas out there?
« Reply #2 on: July 30, 2002, 04:15:58 pm »
Hi!
Check out what I did... I have a rotating monitor and I'm happy with how my glass/bezel
came out.  BTW how are you implementing your swappable panels?  I'm always curious about
people handle those... mine is kinda awkward and time consuming to build panels, but sturdy.
Oh yeah, here's the link:
   http://users.adelphia.net/~bsturk/mame.html
Carsten Carlos
« Reply #3 on: July 31, 2002, 12:34:07 pm »
Hi!
Thanx, I though also if a bezel from Happ (or someone else) would work on a rotating monitor - as I'd like to go the more authentic route I'll try to do it this way, too.
Did the bezel easily fit on your monitor?
My controlpanels are not done yet, so it would take some time until I can show how I made them swap! (hope it works as easy as I want)
Cheers
Carsten Carlos
danny_galaga
  • Last login:Yesterday at 03:59:22 am
    • dans cocktail lounge
Re: Bezel for rotating monitor -any ideas out there?
« Reply #4 on: October 08, 2005, 01:27:10 am »
i just used quad to make a frame and painted everything satin black. if i look closely on mine, there is an actual gap on a corner of the monitor where i hacked it off but you really cant see past the different kinds of black, including the black of nothingness!
