Author Topic: Mini Mayhem  (Read 21102 times)
Stingray
Mini Mayhem
« on: January 26, 2004, 10:25:20 am »
After a couple of months of searching I finally found a suitably dead cab for a MAME conversion. This is a Blueprint cab. I really like the side art, but it's too rough to use. The entire cabinet will be refinished, but I haven't decided on what type of artwork to use on it yet.
-S
« Last Edit: April 27, 2005, 04:02:55 pm by Stingray »
Stingray
Re:Just getting started
« Reply #1 on: January 26, 2004, 02:57:41 pm »
Mockup of my control panel layout. I know most of you guys think this is backward, but I prefer buttons on the left, so that's the way I'm building it. The buttons on the front of the panel will be pause, tab (for accessing the setup menu) player one start & player 2 start.
-S
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #2 on: January 26, 2004, 09:32:28 pm »
I've never heard of Blueprint.  Huh.
Good luck with your project!
Generic Eric
« Reply #3 on: January 26, 2004, 09:37:52 pm »
There is a game called Blue Print in mame.  Might be the same one
HagHore
  • Last login:October 24, 2007, 02:24:00 pm
  • Game Over Man, Game Over!
« Reply #4 on: January 27, 2004, 07:47:01 am »
You could always go with Stargate artwork as I believe that is the same style of cab.
We're on an express elevator to Hell! Goin' down!
Stingray
« Reply #5 on: January 27, 2004, 09:11:38 am »
I hadn't heard of Blueprint either,actually. I'd love to keep the artwork that's on it, but it's in much worse shape than the pictures indicate.
Stargate is pretty similar now that you mention it. A little different control panel shape and the monitor slants back farther in this one, but it's pretty close. I may keep that in mind if I decide to to a reproduction cab. Right now I'm leaning toward original artwork, but I haven't actually sat down to design anything yet.
I intended to make a metal CP last night, but when I got to the shop I couldn't find a peice big enough to use. Gonna have to buy some sheet metal. Spent last night slinging wire instead.
-S
Stingray
« Reply #6 on: January 30, 2004, 12:39:23 pm »
Over the last couple of nights I removed all of the old artwork, even with a heat gun, the decals came off in little pieces, because someone at some point ran a pocket knife all over them and sliced them into little chunks. I'm glad I'm past that part - very tedious. I've got the cab down to just an empty box. The plan is to paint it this weekend. It will be black with blue t-molding. I've got some preliminary design work going for the new graphics, but nothing I'm ready to show yet. If all goes according to plan I should have pics of the cab sporting it's new paint job by Monday.
-S
Stingray
« Reply #7 on: February 02, 2004, 09:37:18 am »
Spent all day Saturday filling holes, deep scratches & gouges with auto body filler. I did so much sanding my arms feel like they're going to fall off! My original intention was to use two part urethane because it's extremely durable, but I ended up using automotive grade enamel instead because I was given some (okay, so I'm cheap). I did put a lot of hardener in the mix though, so after it's had a few days to fully cure it should be pretty tough finish. I'm pretty happy with the results:
I'd love to hear some comments.
-S
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
Re:Just getting started-Update: New paint job
« Reply #8 on: February 02, 2004, 10:34:54 am »
Very nice that glossy finish ...
Stingray
« Reply #9 on: February 02, 2004, 11:47:03 am »
Thanks. My dad has owned a body shop for the last 35 years, and I practicly grew up in the shop. As a result, I'm pretty handy with a paint gun.
It doesn't show, but the inside (the area around the monitor) is a flat black. I did this to cut down on glare.
-S
BobbyG66
  • Last login:November 13, 2016, 11:52:09 am
  • Current project: Dodgeball
« Reply #10 on: February 02, 2004, 12:00:08 pm »
Big improvement, looks good.
Good idea with the flat finish in the monitor area. Will keep that in mind when building my cab...
Half of the people you meet are below average.
Stingray
« Reply #11 on: February 02, 2004, 12:17:03 pm »
I'll be happy to report how it works after I've got everything reassembled & running.
-S
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #12 on: February 02, 2004, 04:18:15 pm »
Yeah that sure looks nice.
Cool idea to use "car paint". Seeing that I wonder why noone used the "chameleon paint" (which changes color when you pass the car) on his cab yet  ::)
Stingray
« Reply #13 on: February 02, 2004, 04:28:05 pm »
Two reasons spring readilly to mind. One, it's super expensive stuff, as much as $1000 a gallon. Two, it will show every little tiny imperfection under the paint.
Er... and it's fantasticly ugly, but that's just my opinion.  ;)  ;D
I apreciate the compliments. Just about to start working on it right now.
-S
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #14 on: February 02, 2004, 04:37:10 pm »
He, he, you might have a point there, but I assumed it was the goal of an arcade cabinet to be as tacky as possible and this stuff would just SCREAM tacky ;D
Forgot to ask earlier, but since you seem to be "hunting" for Galaga art, I guess you are not going with the Stargate theme?
Stingray
« Reply #15 on: February 02, 2004, 08:15:03 pm »
No, not doing Stargate. Not really doing Galaga either, I'm working on a bit of "semi-original" art that's based on the overall look of a Galaga cab.
-S
Stingray
« Reply #16 on: February 03, 2004, 08:44:34 am »
Got the t-molding on and started putting some of the guts back inside it last night.
-S
« Last Edit: February 03, 2004, 08:46:23 am by Stingray »
Stingray
Re:Stingray's Cab *updated Feb. 3
« Reply #17 on: February 03, 2004, 12:59:02 pm »
My not-quite-finished artwork is now posted in the artwork forum:
http://www.arcadecontrols.org/yabbse/index.php?board=13;action=display;threadid=15686
I'd appreciate any feedback you guys may have to offer.
-S
JamesS
  • Last login:May 09, 2014, 03:26:43 pm
  • Just getting Started, Bare with me...
« Reply #18 on: February 03, 2004, 01:22:21 pm »
Your cabinet looks good Stingray.
I am close to finishing up my control panel area, without painting it yet.  Going to hopefully be putting the Monitor shelf in there soon.  Bought the plywood for it anyway.
Stingray
« Reply #19 on: February 03, 2004, 01:51:03 pm »
James, good luck with yours. I got really lucky with my monitor mounting. I pulled the arcade monitor, took my PC monitor out of it's plastic case, and it just fit perfectly in the hole left behind by the arcade monitor. No modification needed at all. All I had to do was screw it down.
Hopefully I'll get my control panel painted tonight and I'll be able to hook it up tomorrow. I am so ready to play test this thing!
-S
« Last Edit: February 03, 2004, 01:54:29 pm by Stingray »
Stingray
« Reply #20 on: February 03, 2004, 07:25:04 pm »
Finished the metal CP, ready to install buttons & sticks. I decided to just spray some primer on it and call it good. It's going to get an overlay anyway.
-S
« Last Edit: February 04, 2004, 08:19:01 am by Stingray »
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #21 on: February 03, 2004, 09:26:36 pm »
Man you work fast! At this rate you'll have that cab done in a week or something.
I wish I could do a metal CP too. This looks so professional  8) I have been messing about with MDF and Lexan with mixed success so far (so far it's Lexan vs Me 1 - 0)  :-\
BTW, Why did you make the holes for the joysticks so large? Do you plan to install them by sticking the whole ball through the panel? Or is it that the button holes are smaller than usual?
Stingray
« Reply #22 on: February 04, 2004, 08:24:06 am »
I used a Cyberball CP as a template to trace my joystick holes. That's the size they were on that panel, and yes, they're large enough to stick the ball up through the bottom of the panel. They're still small enough that the dust covers cover the hole when the joystick is pushed in any direction though.
Here's the panel with the sticks & buttons in it. Nothing is hooked up yet though.
I don't think I'm going to use those two Atari sticks, they don't move as freely as I'd like. I'll probably get a set of new 8 ways to replace them.
-S
PedroSilva
  • Grettings !
« Reply #23 on: February 04, 2004, 08:27:45 am »
Hi,
What color will you use to cover the CP ?
Because if it's black, some of the buttons might die a little, no ?
Stingray
Re:Stingray's Cab *updated Feb. 4
« Reply #24 on: February 04, 2004, 08:33:52 am »
Good point Pedro. At this point my overlay design is mostly black with some blue border. Again, it's similar in design to a Galaga CP. Maybe I should consider going with all blue buttons and get rid of the black ones. What do you think?
-S
PedroSilva
  • Grettings !
« Reply #25 on: February 04, 2004, 08:48:04 am »
-S
Well, in my humble opinion, it seems that you want to give some effect on the CP by crossing the colors of the buttons. If that's what you want, you may change the black buttons to another color (for instance, dark blue) and you would stell get that effect even if the CP is totaly black, or you can put them all in light blue, matching the T-molding ... should also look nice ...
Stingray
« Reply #26 on: February 04, 2004, 08:56:50 am »
Do you know of someone who sells more than one color of blue buttons? These were the only shade of blue that I could find. The CPO will also have some orange in it. Maybe I should use orange buttons instead.
-S
pathdoc2
  • Last login:January 11, 2006, 08:49:53 pm
  • Your friendly pathologist
« Reply #27 on: February 04, 2004, 09:55:01 am »
Very nice metal work.  How did you cut those holes?  How did you bend the metal sheet?
menace
« Reply #28 on: February 04, 2004, 10:05:11 am »
Holy crap man--you must have a clone army assembling your stuff!  Control panel looks great--who would have thought that a body shop could make such great arcade cabinets--tell them they should hire you full time for paint and metal work! ;D
PedroSilva
  • Grettings !
« Reply #29 on: February 04, 2004, 10:21:31 am »
-S
Well ... I'm in Portugal and I got my buttons from a local dealer. He gets the parts in Spain at this company:
http://www.industrias-lorenzo.com/cgi-bin/miva?~lorenzo/listafam2.mv
The one's I use are convex (A0212) type instead of concave, but I think that shouldn't make any diference regarding the colors. There, on the US, I think you might find them at Happ ... I believe that Lorenzo Industries supplys some parts for Happ ... Check it out or try to get them directly from Spain ...  ;D
Hope this helps ...
Stingray
« Reply #30 on: February 04, 2004, 10:34:15 am »
With a hole saw. The harder type that's made for cutting steel.
Sheet metal brake. Which is a big device that's made for bending sheet metal if you're unfamiliar with the term.
Well, my other hobby is car restoration. I guess it's more or less the same skill set that's needed, at least for the cosmetic part.
The body shop is owned by my dad, and I did used to work there, but a long time ago I decided that I'd rather have a cushy office job. I still use the shop often for my own projects.
I appreciate the compliments guys! I wish it seemd like I was going as fast as it seems to look. I feel like I'm making very little progress each night.
-S
« Last Edit: February 04, 2004, 10:36:22 am by Stingray »
Stingray
« Reply #31 on: February 04, 2004, 12:45:57 pm »
Another question. Do you think the two buttons on left-front would look better white than black, to match the two white start buttons on the other side?
-S
PedroSilva
  • Grettings !
« Reply #32 on: February 04, 2004, 01:13:32 pm »
-S
What are they ? Emulation buttons ? Coin buttons ? ... Hey ... all my choices are based on logic ...  ;D
Stingray
« Reply #33 on: February 04, 2004, 01:15:34 pm »
One is pause, the other is tab for configuration purposes.
-S
PedroSilva
  • Grettings !
« Reply #34 on: February 04, 2004, 01:27:00 pm »
-S
Well ... for me I'd put the tab Black (Emulation always hiden) and the pause on another color.
Stingray
« Reply #35 on: February 05, 2004, 08:39:38 am »
Last night I gutted an older Power Mac G3, and transfered the insides into my cab.
I have a lot of cleaning up to do, but it's all in there and working.
The cab is now running under it's own power! (previously it was connected to my Powerbook)
Hopefully tonight I'll be able to get the controls all reconnected and then I can "test" it with MAME! I feel like I'm finally getting somewhere.  8)
-S
Stingray
Re:Stingray's Cab *updated Feb. 5
« Reply #36 on: February 05, 2004, 10:51:49 am »
I mounted the CD ROM inside the coin door. This seemed like a good idea to make it easier to add software without having to go in through the back panel. This may be common practice for all I know, anyone else done this?
-S
Stingray
« Reply #37 on: February 06, 2004, 08:59:04 am »
Added the tinted plexi over the monitor. Makes a big difference in looks.
Also it doesn't show, but I got all of the controls connected back up. After I did that I didn't do much other than play... I mean test the controls.
It's going to be really hard to finish this thing now that it's playable!
-S
Witchboard
Re:Stingray's Cab *updated Feb. 6
« Reply #38 on: February 06, 2004, 09:19:41 am »
Looking good.  Everyday I check your thread and I see your cab coming together step by step.  Makes my itchy to get busy on mine.
Stingray
« Reply #39 on: February 06, 2004, 10:23:58 am »
Thanks. I'm really happy with the amount of progress I've made on it this week. I can't wait to get off work today so I can get back on it. I think I'll probably do the coin door next. Right now I have a temporary switch that's just hanging loose inside the door opening for 'insert coin'. Kills a little bit of the authenticity.  :-\
I still have the Galaga theme music going in hy head after last night's "testing" session.  8)
-S
