Author Topic: CHDMAN failing backing up 500gb SSD  (Read 1763 times)
jimmyfloyd
  • Last login:April 04, 2025, 05:01:43 pm
« on: March 17, 2017, 05:05:15 pm »
I am trying to make a backup of my GT2016, which is on a 512gb SSD. I would like to move it to a smaller HDD/SSD to repurpose the current SSD. When I try to use CHDMAN .140, It finds the CHS values, but Fails with an Out of Memory error. When I try it with CHDMAN .146, it first gives me a Can't Determine CHS values error, then, if I enter the values found in the .140 output for the chs, it will start, but fail before it even gets to .5%.
Is chdman the right tool for this, or should I look into another one?
B2K24
  • Last login:June 10, 2025, 10:17:56 am
Re: CHDMAN failing backing up 500gb SSD
« Reply #1 on: March 17, 2017, 05:14:34 pm »
Try the latest version from mamedev.org
MAME is at version 0.183 currently. Using ancient versions of CHDMAN is not a good idea at all.
