Author Topic: RETROARCH - Problems mapping anything to it  (Read 3231 times)
usaf-lt-g
  • Last login:October 04, 2024, 10:05:30 pm
« on: March 01, 2017, 07:23:53 pm »
I actually have a few problems but Retroarch seems to be nasty thorn in my side.
I use HyperSpin/RocketLauncher/LEDBlinky flawlessly now on MAME. However I've seen loads of posts of people raving about Retroarch and how great it is... Yet... I for the life of me can not get it to play nicely at all for any emulator let alone the UI itself.
My CP is a 4 player setup with some extra admin buttons all hooked up through an Ultimarc Ultimate I/O board. I can get Retroarch to launch correctly and I've tried to setup Sega Genesis, Nintendo, SNES, TG16, and Atari but for the life of me, I can NOT seem to get the joysticks to map correctly or the buttons.
I think the intuitiveness of the interface isn't meant for Arcade Style CPs... But maybe that's just me. There's nothing super special about my CP other than it looks nice. Happ Comp Joysticks, Ultimarc uled buttons, a u-track, and a u-spinner...
Has anyone else been successful in this? Should I just say f it, and download standalone emulators for each system instead? I was trying to simplify the process and apparently it's not helping.
Also another problem... daphne.... I'm running my screen in a vertical position. game launches, I can hear sound.... But there's no picture for any game being launched.
wemr97dl
  • Last login:October 16, 2025, 04:44:42 pm
  • KEEP GOING!
Re: RETROARCH - Problems mapping anything to it
« Reply #1 on: March 06, 2017, 06:35:53 am »
I'm messing with it now and not having any luck, but still trying for now. I have an ipac 4 and can't get any controls mapped for it either.
wemr97dl
  • KEEP GOING!
« Reply #2 on: March 06, 2017, 09:22:42 pm »
I just set up sega genesis and finally did get my ipac 4 mapped correctly, I have not done any other system.
What i found helpful was this page
https://github.com/RetroPie/RetroPie-setup/wiki/RetroArch-Configuration
I printed out a pic of the Megadrive/Genesis (6 Button) controller and used as a guide when mapping.
under inputs, I have it set to retropad, I'm not at my computer right now and connot remember the setting but a few settings down is another setting that has an option of Ipac4 and set that to it, with the picture and my CP same layout a yours i was able to map all my controls one at a time, its just easier than hitting all and rushing threw them. The only problem I had is the player one joystick kept showing up numpad 8,6,4,and 2. I had to open up the config file in notepad++ and change them to up down left and right, its way down the list you'll find it if you have to. After thinking about it I may have my numbers lock on my keyboard  which may be causing it?
Like I said I am staring a new Rocket launcher set up and trying to get everything updated so this is the only one I have done and everything seems to be working great for now.
Also using the images you can get the idea of how each different systems controllers corrisponds to the Retroarch Pad setup
hoop it helps
wemr97dl
  • KEEP GOING!
« Reply #3 on: March 06, 2017, 09:48:59 pm »
hoop it helps
Hope
One more thing make sure you save each player as you do it. I kept getting an error when saving player 4 but when I checked the coding file it was all there haven't tried the player 4 controls yet but if there is a problem I'll post it here
