Author Topic: Larger Plastics  (Read 1792 times)
thewisteron
  • Last login:May 03, 2020, 08:04:40 pm
Larger Plastics
« on: February 28, 2017, 10:41:01 pm »
So where does everyone get their larger plastics for your CPs that are more than 36"? Also while you're here, what type do you prefer? What thickness do you prefer?
« Last Edit: February 28, 2017, 10:43:28 pm by thewisteron »
UEDan
  • Last login:November 10, 2019, 05:54:08 am
Re: Larger Plastics
« Reply #1 on: March 01, 2017, 03:15:14 am »
Plastic shops. I have a few shops locally I use:
https://www.yelp.com/biz/paragon-plastics-santa-ana
http://www.cuttingedgeplastics.com/
I found the second one by calling one of those custom container/shelving/engraving stores and asked for a large unfinished piece of acrylic.
They pointed me to their supplier.
Home depot and Lowes sells large sheets as well, price sucks compared to plastic shops.
I like 1/16th inch acrylic(plexiglass). Clear and stands up to scuff real well. Its also easier to score and snap.
Using 2 sheets as a marquee holder.
Do not use 1/8" on 3/4" MDF for the control panel. Too thick, 1/16' is enough.
n3wt0n
  • Last login:July 12, 2025, 09:56:52 am
Re: Larger Plastics
« Reply #2 on: March 01, 2017, 08:03:19 am »
If you plan on using t molding around the edge of your panel I would consider using 5/8" wood with 1/8" plexi so you finish at 3/4" and can still use the most common size molding available.
UEDan
Re: Larger Plastics
« Reply #3 on: March 01, 2017, 12:18:11 pm »
That would have been the smarter thing to do.... but its not carried in smaller panels at the hardware store.
Maybe I should just look for a lumber yard...
thewisteron
Re: Larger Plastics
« Reply #4 on: March 01, 2017, 03:03:34 pm »
Thanks for the advice. I did some calling around and found a place that will cut me a 24" x 48" x 1/16" for $25. I'm going with it. I think I'll do 1/16" plastic + 3/4" MDF and just take the bottom edge off of the MDF before I put the 3/4" moulding on. It is only the control panel so it shouldn't be hard...I hope.
UEDan
Re: Larger Plastics
« Reply #5 on: March 01, 2017, 04:13:53 pm »
You could just buy 13/16" t-molding and do an off centered slot cut.
https://www.t-molding.com/smooth-081in.html
thewisteron
Re: Larger Plastics
« Reply #6 on: March 01, 2017, 11:00:48 pm »
Ended up stopping at Home Depot just to see what they had. To my surprise, they had 24" x 48" x .093" Optix acrylic for $27, so I just bought it. Not sure why .093, but it will work.
