Author Topic: I need a favour please : DIMENSIONS / Galaga U/R  (Read 8847 times)
General Zod
  • Last login:June 23, 2005, 03:58:28 pm
  • Banned
« on: January 25, 2004, 10:43:55 am »
Does anyone happen to have the dimensions of a Galaga Upright cabinet?
I'm not so concerned with the width , as I am the height and depth ...
Thanks in advance !!  ;)
Mike
patrickl
  • Yo momma llama
    • PocketGalaga
Re:I need a favour please : DIMENSIONS / Galaga U/R
« Reply #1 on: January 25, 2004, 10:47:14 am »
I might be misunderstanding your question, but did you see the sticky thread "Any interest in original cab dimensions "? All known cab dimensions are collected there.
General Zod
  • Banned
« Reply #2 on: January 25, 2004, 11:17:47 am »
That was the first place I researched , and still couldn't find the answer.
It looked as if JAKOBUD's site might have had the original specs, but it's down at the moment. I did see another, but it looks more like a pac/galaxian than Galaga.
I'm pretty sure the specs are almost similar give or take an inch or two.
I won't have the cab in my possession until the latter part of next week, but I wanted to jump the gun and make preparations for the arrival.
Will I be MAME'ing it ? No-way!! ... but I do have to shop and dress it accordingly.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #3 on: January 25, 2004, 11:27:39 am »
Weird, I have no trouble getting onto jakobuds site.
Another option is Wouter's page  Arcade Cabinet dimensions (Allthough these contain some false measurements)
« Last Edit: January 25, 2004, 11:29:03 am by patrickl »
General Zod
  • Banned
« Reply #4 on: January 25, 2004, 12:00:30 pm »
If Wouter's page is even close on some of those numbers, it's plenty for what I'm needing to know.
I must have overlooked that somehow. I remember seeing Jakobud's site, still on luck getting in ... must be my isp >:(  and some site that had a few plans like galaga, tempest, sinistar etc...
Wouter's  did the trick though  ... thanks !!  ;)
GZ
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #5 on: January 25, 2004, 03:06:48 pm »
There is some confusion (well at least I'm confused) what the actual height is. Wouter's page says 67.5" and jakobuds measurements add up to about 66.5" (as I remember). But it could also be that they measured at a different point.
The depth is another issue. The bottom part is probably 30.5" deep at the bottom and 31.5"just below the CP.
BTW, are you getting a complete Galaga cabinet (with all the artwork on it)? If so, were you planning on some vectorizing? I'm still looking for a (set of) high res bezel picture(s) Also, I've vectorized the CPO, but I'm still not sure about the colors.
General Zod
  • Banned
« Reply #6 on: January 25, 2004, 03:30:43 pm »
I believe the Galaga board , or something internal is causing a few problems with the cab. Anyhow, the board is being replaced by a 6'n'1 Jamma PCB.
It just so happens that Galaga is on the new Jamma.
I havent seen the cab except for the front/top, as it was behind what looked like an army of cabs.  (perfectly lined up, about 15-20 across, 10 rows back. ) I ruined a pair of britches while in that warehouse!  ;D
Anyway, sorry for the rambling.  ::)  I need to design something new, and was curious how big of an area I actually have to play on.
After thinking of my original request, I should have worded the headline differently to read side-art specs. As I'm hoping to create a comparable image using the same dimensions as the original.   :P
I still appreciate your taking time to show me the links I overlooked.
BTW ... If it turns out the bezel is still in place, I can shoot an ultra hi-res image for the board and pass it along for someone to vectorize.
I'll know more as it makes its way from the back row to the front.
Mike
Jakobud
  • Last login:November 18, 2025, 02:28:46 am
« Reply #7 on: January 25, 2004, 03:49:09 pm »
No my site is up.  The Galaga/MsPacMan plans are on there too.  Let me know if it's problems with your ISP and I will email you the dimensions.
« Last Edit: January 25, 2004, 03:50:03 pm by Jakobud »
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #8 on: January 25, 2004, 03:50:47 pm »
He, he, that must be cool, not knowing what you get exactly ;D In fact it's the same with me as I still have to build my cab  :o
If you find there is still a Galaga bezel in there you'd really make my day with some pictures that I can vectorize.
