Author Topic: vertical cabinet control panel  (Read 1724 times)
Iceman81
  • Last login:November 30, 2018, 05:57:54 am
« on: February 26, 2017, 10:52:53 am »
hello, i am looking to do a vertical cab, and i wanted to use the "midway" style metal control panel that is converted for multicade.  Basically has 1 controller, 3 buttons, 2 1/4" trackball and 2 player buttons.
My question is, should i put the 5 pushbuttons with an ipac usb board, or connect the 3 push buttons to the usb trackball interface, with the 2 player buttons by themselves on the ipac?
I have never used the I-PAC board btw, my main cabinet uses a "xin mo" board and doesn't have a place for a trackball(which im using usb).
If i use the ipac, do i need a usb/ps2 trackball, or just the regular one and connect everything to the ipac?
velcrobomb
  • Last login:September 17, 2025, 02:04:08 pm
Re: vertical cabinet control panel
« Reply #1 on: February 26, 2017, 12:57:52 pm »
The buttons and joystick will need a keyboard encoder, which is your iPac.  For the trackball, depending on what type you get, more than likely you will need an optical encoder.  I believe some brands of trackball have direct usb support.  I imagine your trackball has those pushbutton connectors for things like mouse buttons.
I'm fairly new myself so if I stated anything wrong, please correct me.
paigeoliver
  • Awesome face!
« Reply #2 on: February 26, 2017, 02:09:38 pm »
I would definitely hook up 2 trackball buttons so you have proper mouse support outside of mame.
Iceman81
« Reply #3 on: February 26, 2017, 04:43:45 pm »
yeah that makes sense.  I have 3 buttons setup up on my main cab trackball and that works good in a pinch, but i also have a small wireless keyboard/mouse combo that i use as well.
cj138
  • Last login:May 23, 2018, 06:56:39 pm
« Reply #4 on: February 27, 2017, 05:01:51 pm »
You can wire a standard arcade trackball to an Ipac 2, so you do not need an optical encoder. I also would not bother wiring mouse buttons. Just throw a mouse in the cabinet if you need to do admin stuff.
