Author Topic: San Francisco Rush - Steering Wheel not responding  (Read 5732 times)
jevansoh
  • Last login:February 23, 2023, 04:56:52 pm
« on: February 25, 2017, 10:45:02 pm »
I'm trying to get SF Rush to work properly but when I load the game in mame it says, "Steering wheel not responding, Press abort to continue" but even though it says that, I can turn the wheel and it shows it's moving on the screen.
Once I press abort I can load the game and when I am selecting a car, transmission, track, etc, the wheel operates just fine and seems like it is on the right sensitivity but once the race starts, no matter how far I turn the wheel left or right, it just doesn't respond at all.
I'd really appreciate some help with this.  I just got a Logitech 920 and am not having very much luck or very much fun so far. :(
In the Logitech software, I tried setting the wheel all the way down to 40 for rotation and that had no effect whatsoever.
Thanks,
--J
« Last Edit: February 25, 2017, 10:53:15 pm by jevansoh »
MTPPC
Re: San Francisco Rush - Steering Wheel not responding
« Reply #1 on: March 01, 2017, 11:34:35 am »
That's because the startup sequence uses the FFB motorto calibrate the wheel at the beginning. Press the abort button on your keyboard. Then see if the game starts up. I have no idea which key it is.
http://pinballmd.com/
jevansoh
« Reply #2 on: March 03, 2017, 01:18:34 am »
That makes total sense.  Thanks so much!
isamu
  • Last login:January 14, 2026, 06:54:24 pm
« Reply #3 on: March 03, 2017, 05:29:11 pm »
Just out of curiosity did Howard ever get MameHooker to support the FFB effects from any of these Atari racers(Rush series, CruisN, etc)?
xlegx
  • Last login:December 08, 2020, 04:42:37 pm
« Reply #4 on: December 08, 2020, 12:49:30 pm »
Hi! i'm in the same situation with San Francisco Rush Alcatraz for Mame. I can select everything but when the race starts, i can't turn right or left the car at all. I've tryed to abort the FFB test, but it's useless.
 I don't have this problem with the normal SF Rush, it only happen with this version. Can someone help me?
EDIT: Problem solved! The issue was that brake and gas were in the same pedal (Accelerator) even if brake was not setted into anyone pedal ----> I'm using Logitech G29 on Mame.
Giving to Pedal 1 Analog= Joy 1 Accelerator (-) , Pedal 2 Analog Inc = Brake (-) and Pedal 3 Analog Inc = Joy 1 down, the problem disappeared!
Also the Force Feedback has start to work properly and now everything works great! Expecially setting the clutch on pedal 3, i don't know why, but it starts to work fine.
NB: Remember to set into Analog controls menu, the correct setting of each pedal reverse mode (On or Off) depending on what you have setted before on control commands.
Example: Pedal 2 Analog Inc = Brake (-)------>P1 Pedal 2 Reverse OFF (not ON). Set On only if you had set Brake (+)
« Last Edit: December 08, 2020, 04:21:08 pm by xlegx »
