Author Topic: Do I need resistors when powering 12V LEDs with PC12V?  (Read 2430 times)
1UP
  • Token Junkie
    • 1UPArcade
« on: January 25, 2004, 02:58:35 am »
Do I need to use resistors when powering 12V LEDs with 12V from the PC power supply?
I'm putting some 12V superbright LEDS into my Happ illuminated pushbuttons.  Since the LEDS are already 12V, do I need any kind of limiting resistor?
Thanks.
My other job...
Tiger-Heli
    • Tiger-Heli
Re:Do I need resistors when powering 12V LEDs with PC12V?
« Reply #1 on: January 25, 2004, 09:13:48 am »
Thanks.
AFAIK, 12V LED's include an integral resistor so no additional one is required.  At least I know that's how 5V ones work.
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #2 on: January 25, 2004, 08:09:18 pm »
As TigerHeli says, The 12volt LEDs should have a built in resistor.
American Laser Games Wrapper
O2em Rom Utility
1UP
  • Token Junkie
    • 1UPArcade
« Reply #3 on: January 25, 2004, 08:43:59 pm »
Thanks, that makes things easy.
My other job...
DarkKobold
  • Last login:June 18, 2013, 11:31:23 pm
« Reply #4 on: January 25, 2004, 10:57:26 pm »
1UP - during my senior design class, I worked with those super bright leds, from superbrightleds.com... they don't NEED a resistor - but they sure are safer with them. I had a few burn out when we plugged them directly into the power supply. After that, we added 100 Ohm resistors into our specs. It didn't affect the brightness much, and it did stop us from wasting the bayonet bulbs.
My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working)
My wants: Warlords Cocktail
micro571
  • Last login:January 02, 2006, 03:46:30 pm
    • .:: JBProjects.net ::.
« Reply #5 on: January 26, 2004, 12:38:40 am »
If you want to have some fun...hook the 5V LEDs up to the 12V of the comp's power supply.  You get very unpredicatable results.  Some explode, some just fizzle out, and some go up in a big puff of smoke.  Hours of fun for pennies a pop =)
-= Mame Arcade Machine * LED Screen * Potato Gun * LED Matrix * PC RC Car =-
www.JBProjects.net
