Author Topic: rockola 940 with a slow turntable  (Read 3505 times)
George
  • Last login:February 18, 2017, 06:35:13 pm
« on: February 15, 2017, 07:52:29 am »
I am new to this forum so please bear with me. One of my three juke boxes is a rockola 940 that has always worked well, but it hasn't been played in a while. After start up, I noticed that everything worked but the turntable was spinning 34 rpms like for playing an LP. The voltage to the turntable motor is 120 volts and I don't see any binding of the drive wheel or platter. I did notice that the power distribution box has four monitor lamps. The second lamp, labeled -28v, has a very faint glow unlike the other three which are bright. Any help would be greatly appreciated and thank you for the opportunity to post my problem.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: rockola 940 with a slow turntable
« Reply #1 on: February 16, 2017, 05:57:13 am »
Hi George,
I do not know of a Rock Ola 940 are you sure you have the correct model number, leds for the power rails on the power supply (junction box) would indicate it is a 70' or early 80's jukebox.
You say that the turntable motor is a 120 volt motor (this is bassically the same motor that is used on the 1100 & 1200 mechanisms on the Rowe Ami jukeboxes) does you jukebox have speed shift options of 45rpm & 33.3rpm? if this is the case then I would look for any switching in this area.
Regarding the dim led have you measured your voltage rails to see that you are getting the -28 volts DC?
Regards
Alan
Alan Hood
ami-man
UK
George
Re: rockola 490 with a slow turntable
« Reply #2 on: February 16, 2017, 08:51:57 pm »
Hello Alan;
               Thanks for catching my mistake. My juke box is a Rockola 490 made around 1984. I think I found the problem. The three nylon bushings that hold the turntable motor collapsed under the washers and e-clips that hold them in place. This allowed the motor to sag causing the drive wheel to ride on a part of the motor shaft that is smaller in diameter thereby slowing the rpm down. Thank you for steering me in the right direction.
        George
