Author Topic: Servostik rotating issue  (Read 1766 times)
cybermat
  • Last login:March 05, 2025, 12:14:11 pm
« on: February 14, 2017, 04:26:27 am »
Hello,
i bought some months ago from arcadeworld this stick, i noted that the rotating plate sometimes stucks in the middle (on youtube there is a video similar to my issue). I thought that this issue had been resolved. I fixed this loosing the screws, up to almost removing them, but i think that this not a good idea.
In a review of this product, the user had been able to fix this "sanding down" , could you please show how to fix this issue ?
" Great product
Posted by John on 26th Dec 2016
Bought this (and the servo control board) to replace the standard 8-way joystick in my Mayflash F300 fight stick, which I use with RetroPie. The only problem I had with it was that the ring was a little tight and the motor wouldn't switch smoothly from 4-way to 8-way. However, after a small amount of sanding down it works fine and now I can play Pacman and Scramble :)"
Thanks a lot
cybermat
Re: Servostik rotating issue
« Reply #1 on: February 15, 2017, 03:32:06 am »
I used a nail file and i smoothed the restrictor plate (outward). Now the motor is able to perform 4-8 ways flawlessy.
« Last Edit: February 15, 2017, 05:56:36 am by cybermat »
Laythe
  • Last login:October 12, 2025, 01:10:49 am
« Reply #2 on: February 15, 2017, 03:51:16 pm »
I removed the hair-fine washer springs from mine because they'd jump into the bore and drag.  I replaced the washers with much larger washers.  I lubricated the heck out of the restrictor plate, and then ran the screws down with removable loc-tite in them until the restrictor would rattle slightly but couldn't tilt much.
Mine work well now.
danny_galaga
  • Last login:Today at 03:43:09 am
    • dans cocktail lounge
« Reply #3 on: February 16, 2017, 01:18:51 am »
Mine work well now.
I had a very similar experience. I wrote about it here (near end of thread)
http://forum.arcadecontrols.com/index.php/topic,132157.msg1521798.html#msg1521798
and included some pics. Only difference is I kept the springs and bent them so they couldn't wind their way in (",)
