Author Topic: Cell phone mini cab  (Read 8815 times)
rhoelsch
  • Last login:August 18, 2018, 08:13:16 pm
  • That...that thing's operational!
Cell phone mini cab
« on: February 12, 2017, 05:05:30 pm »
**************most recent pics added to this post****************
My Galaxy S7 will slide in whenever the mood strikes.... or maybe my old S4 permanently. Joy via Digikey and buttons and usb interface from A-zon. Marquee, hoping to find a battery operated led Keychain. Wood will be 5mm mdf. 5 or 6 buttons for multiple emus.
« Last Edit: May 26, 2017, 02:10:13 pm by rhoelsch »
Now witness the power of this FULLY OPERATIONAL Mame machine!
Dal1980
  • Last login:January 25, 2026, 02:27:53 pm
  • Load "1980"
    • retro.zombiesbyte.com/projects
    • Retro Zombies Byte
Re: Cell phone mini cab
« Reply #1 on: February 12, 2017, 07:48:17 pm »
Haha - that's awesome. Little joystick is cute. I like everything about this  :applaud:
Have you thought about lowering the CP just in case someone can't reach the controls?  :laugh2:
Please share more, subscribed.
I'm on my last life, best not try anything stupid
-> Check out my other projects at http://retro.zombiesbyte.com/projects
05SRT4
  • Check out my Pow Pow
« Reply #2 on: February 12, 2017, 08:05:03 pm »
cool mini build. Ive seen a couple of cell phone/tablet builds lately.
rhoelsch
« Reply #3 on: February 12, 2017, 08:06:34 pm »
Next will be a working mockup using foam board. I'll need to incorporate some small buttons for Coin, Start, and Exit as well. Should go much faster than the 2 years it took to plan and build my full size cab!😁 At least I don't have to Daisy chain grounds in that small amount of real estate.
rhoelsch
« Reply #4 on: March 07, 2017, 07:46:15 pm »
Slow going, but have to get the dimensions right to fit my phone. Controls and interface are bought, cutting the cp and figuring out artwork will be the only p.i.t.a. obstacles I can see coming up.
« Last Edit: March 10, 2017, 06:41:30 pm by rhoelsch »
Dal1980
  • Load "1980"
« Reply #5 on: March 10, 2017, 06:59:37 am »
Awesome keep going
Sent from my Nexus 6P using Tapatalk
Scassidy24
  • Last login:October 12, 2023, 11:56:34 am
  • I love my Nostalgia Machine
    • forum.arcadecontrols.com/index.php/topic,150379.0.html
« Reply #6 on: March 10, 2017, 11:03:01 am »
That's really cool. Nice bartop machine
mafiafan123
  • Last login:March 01, 2022, 01:13:01 pm
  • i'd buy that for a dollar
« Reply #7 on: March 10, 2017, 12:06:14 pm »
What am I going to do with these tiny hands?! Play this arcade lol
thomas_surles
« Reply #8 on: March 10, 2017, 12:09:33 pm »
Slippyblade
« Reply #9 on: March 11, 2017, 12:41:11 am »
Can you link the stick please?
Slippyblade
« Reply #11 on: March 11, 2017, 01:46:49 am »
Ah, was hoping there was a new model out or something.  Just boggles me how much those cost.
rhoelsch
« Reply #12 on: March 12, 2017, 02:29:03 pm »
Not the final marquee, buttons not wired, and phone is actually resting on the micro to usb adaptor rather than the supports. Small administration buttons to be added near base: coin, start and exit. One of my joy solders has come undone. Verified emulators work with display on top: snes, gba, genesis  and n64. Purchased Cricut vinyl paper for artwork. Still deciding on theme.
Dal1980
  • Load "1980"
« Reply #13 on: March 12, 2017, 04:42:23 pm »
I'm just putting this out there but what about a Micro machines theme :)
05SRT4
« Reply #14 on: March 12, 2017, 05:47:40 pm »
Yeah I remember dropping like 60 bucks on a couple for my mini.
OP do you have plans to add t-molding or a coin door?
rhoelsch
« Reply #15 on: March 12, 2017, 06:22:01 pm »
T-moulding will be likely after I get it up and running. I'd like to have some kind of cosmetic coin door on there. I want to make sure it can function as I need it to, then think about some extras. Maybe add a flask and a PEZ dispenser.
Richie_jones
« Reply #16 on: March 12, 2017, 08:54:32 pm »
Can you link the usb board, thanks
Sent from my SM-P900 using Tapatalk
rhoelsch
rhoelsch
« Reply #18 on: March 21, 2017, 07:49:57 pm »
Progress made. Primed and first coat of paint on. Marquee tested using copy paper. Marquee plastic cut. Holes drilled in front bottom for admin buttons. Lighting solution tested. Back and top cut. More paint coming, then side art will be printed and applied. Need solution for top removal or hinge, since phone slides in from top. Need to decide on artwork/color for control panel, as well as a solution for a dust washer. CP assembly and soldering will be last, if I can hold off wanting to play it. Hard to take my time.
05SRT4
« Reply #19 on: March 21, 2017, 11:22:07 pm »
I just used a black sharpie on a nylon washer for the dust washer on my build.
rhoelsch
« Reply #20 on: May 26, 2017, 02:13:51 pm »
« Last Edit: May 26, 2017, 02:25:42 pm by rhoelsch »
